Noob "Must Have" Electrical Tools?
Colin Len
Long Beach CA
Hello all, I recently purchased my first home and plan on replacing all of the light fixtures/fans, switches, and outlets. I've done minor electrical work before but nothing more extreme than simply replacing a switch/outlet or running a new outlet in a garage. I'm much more comfortable with 12v DC automotive wiring (of which I've done a LOT) but haven't been exposed much to AC electrical systems. Most of what I want to do around the house should be straight forward, but there are items which do not function (porch light for example) and it appears I will need to do some troubleshooting to find and fix the problem.
So, what are those "must have" tools for any homeowner who wants to do their own work around the house? I have a multi-meter already, although I've never used it on AC electrical components, only DC. And I also have some wire crimper/strippers. Mainly wondering what sort of diagnostic tools there may be - stuff to check for if a wire is hot or not...etc
Any help is appreciated.
southalabama
Brewton AL
Get a non contact voltage detector, klein has one at Home Depot.
You've got a multi-meter, strippers.
Surely you have screwdrivers too
Not much else
marinepride
ohio
All though i am a professional electrician i think my set up will serve you well.
Non contact voltage tester as has been said, a wiggy and an outlet tester is also helpful, dykes, wire strippers, needlenose pliers....
lbmcse
Sidecutters, 10 in 1 screwdriver, or two sets of slotted and Phillips (#1 and #2) screwdrivers, trim screwdriver, diagonal cutters, needle nose pliers, wire strippers, multimeter, non-contact voltage detector (tick tracer), channel locks. This'll get you started.
SlowAl
You may run in to those slotted phillips screws on newer outlets. I think the wiha terminal screwdriver is the only one I've used that actually fit these screws correctly and didn't strip them out.
For $10 its worth having just in case.
mobiledynamics
Gotham City
I like to use PH2 to set the screws but ALWAYS take a flat to finish it off and get more torque. No need for the above Wiha IMO
Breakers - #2 Square is more than sufficuen.t
lbmcse
Agreed. I use the Roberts tip of my Klein 11 in 1 for those screws. They work perfectly. That tip holds it so well, sometimes when the screwdriver is pulled out, the tip remains in the screw head! :)
schor
Ajax, Ontario
Being a Canadian I have a full set (actually multiples) of Robertson screwdrivers.
I think everyone has covered the basics of what you should have except for perhaps a book (or google searches) on house wiring since your really a noob at AC.
bill in in
Best tools is the same for about everything, but more especially electrical- knowledge. You should understand hots and neutrals, grounds, and how to use various connections. I've rewired old houses with all kinds of wiring methods but any method done right seems to have held up. I've also seen many failures due to poor technique/application. Knowledge just isn't as fun as a new tool, but it does save yer rear portion fairly often.
gdh33
Northern Ontario, Canada
You should have all you need. Non-contact voltage tester is nice, but not needed. Need screwdrivers (phillips, flat/standard if you are in The States, Robertson if in Canada), wire strippers/cutters, multimeter and I use a lot of paper to sketch out circuits that do not work or that I am changing. Take your time and ensure the power is off. If you can troubleshoot vehicle DC systems, you are golden. Switch the Live/supply (should be black wire) first if possible then feed to light/fan.
edit to say, google and common sense are your friends for troubleshooting/fixing.
ishiboo
Oshkosh, WI
Pratt-Read (Menards Masterforce) makes a compatible bit, as does Milwaukee (ECX).
Non-contact voltage detector as people stated, plug-in outlet tester (with a GFCI test button is nice to have.)
Klein 11-in-1 screwdriver (get the tan 5/16" wire nuts that have a hex head) and Klein Kurve NM stripper will serve you well.
mod600
Central Minnesota
Which model do you use?
30700
30701
30711
30712
My Old Tools
Hamrick Lake, TX
I bought a "Fox and Hound" circuit tracer by Tipplett. It was $40+ on Amazon and worth every penny if you have plugs and switches that don't work and you don't know where they go or what circuit they are on. Helped me find an outdoor plug problem. Not only was it switched, it also had never been terminated to a breaker. I found the right wire capped off in one of my panels.
General Geoff
Allentown, Pennsylvania
I'm a DIYer and have done my fair share of automotive and residential electrical work, I get by with:
Multimeter
Lineman's pliers
Needlenose pliers
6-in-one screwdriver
Miniature diagonal cutters and precision pliers.
I use the miniature diag cutters to strip wire, as I just haven't found a good quality wire stripper that I like. It's slower but it gets the job done on any gauge wire. Just have to be careful.
mopho
Buy as you go but buy nice stuff your old now and if you buy quality stuff it will outlast you.
That being said a pair of Klein 9's will do just about everything. They are the duct tape of the electrical world.
