My garage is roughly 24' x 22'. I'll try to describe it the best I can. If you are standing at the front of the garage (facing inward) with the large garage door open this is what it looks like:
Against the back wall (opposite the big garage door) I have three work benches lining pretty much the entire wall.
To the left I built shelving that is attached to the wall and runs up to the rafters.
3/4 of the garage is open rafters while the back 1/4 (over the work benches) is finished. I believe it is for a fire break but not positive.
Here's my plan.....
At the present I have (4) 4ft 2 bulb flourescent light strips (T12 unfortunately) starting at the beginning of the rafters. They are paired into two large strips if that makes sense. There is no lighting over the finished portion of the garage which makes working at my benches extremely difficult.
What I want to do is add another circuit to my breaker box, run that circuit to the garage. Add a new box with two switches on the on the wall at the door going into the house. Then I want to run a long strip of plugs long the wall above my work benches. Thinking around 9ft long.
I want to get rid of the (4) light strips I have now. Replace with (2) 8ft 2 bulb T8 Lights. Then I want to run either the (4) lights I have or go buy (4) 4 ft T8 light strips and run those width wise over my work benches and along the edge of the finished ceiling.
I know this is a little winded but I want to make sure I am doing this the correct way. I made a quick diagram of what the garage looks like. I can take a picture if that would be better.
Here's my plan.....
