VT-Rider
Hi, Noobie Lurker here. Hi!
I’m building a heated 30x30 detached garage/shop at 2250’ in central Vermont. 6” 4000 psi concrete floor for possible 4-post (Advantage) moveable lift, with 8” stub wall. 2x6x12 side walls, WF18 steel center beam, 12x2x15 first floor ceiling beams, 12/12 pitch gable roof with 12x2 roof rafters. Two 10x10 insulated doors w/jack shaft openers. Hardi plank siding. Screwed on black metal roof. 19/34 insulation. Several questions:
1. Heat with a Modine Hot Dawg HDS45 (outside combustion air) 45,000 BTU. I’d normally keep space at ~50F (65F when working there) and Modine recommends SS heat exchanger due to more condensation. I’d also like dual range burner, 50% for normal operation, 100% when doors open. However, Modine does not offer that 45KBTU (SS / variable) configuration. What’s more important, SS burner or dual range?
2. As I want to heat 2nd floor, do I need knee walls and a ceiling, or just run roof rafters up to the 15’ (12/12) high point?
3. ZIP sheathing or plywood and Tyvec? Builder says when he tapes Zip as he goes, doesn’t have a Zip roller. I’m leaning toward ply/Tyvec.
4. Closed cell (purple) closed cell foam or rock wool insulation? Even if foam is exothermic, is there a min recommended application temp? It’s getting cold here. Do I need to ventilate the roof (as with rock wool), or just spray insulation on the underside of the Zip/plywood roof?
Probably a lot more... Thanks
