Norwegian west coast garage
TRS63
Stuttgart, Germany
I don't know how I did miss this topic but I really love your garage, clean, well organised and well equipped:thumbup::thumbup:
I spy some vw parts in the parts washer, you are also rebuilding a flat-4 engine?
Antoine
P
Pogona
Hordaland, Norway
hi guys!
been way to long without an update here so im gonna try and catch up, and this update is going to be HUGE as you guys say in america now :p
me and my better half bought a in the end of 2015 so last year was quite busy with work offshore in africa, work in the shop and with the new house. the new house is situated in a quiet area just 8 minutes away from the shop, its also very close to the sea, actually a stones throw as we say here in norway and unlike the standard housing lots here these days its a big lot at about 1500 square meters so i see a potential for a big workshop at home as well but building anything here in norway is expensive so thats a bit down the road, but i have slowly started preparations to make a foundation for a new shop with the help from a couple of buddies who borrowed me a small escavator and a HUGE fasttrac tractor to haul the dirt away. got a big project ahead just changing out the soil for solid rock foundation but little by little im getting there.
about 33 of the near 5-600 tonnes of rock needed is in place.
a well deserved pizza break after a lot of digging.
enjoying a cool Cider in the garden after a long day of digging.
the new house only has a small one car garage with separate gymroom in the back and a room on top of the garage that im going to make a man cave out of. we filled the gym with all sorts of fitness equipment but between me and my misses we have probably spent less than ten hours there so i convinced her to move the gym equipment into the small cabin in the garden and leave it there for a year or so and sell it off if we dont use it more, and that will leave some space for me to use for more usefull things. so next task will be to open up the wall between the garage and the gym and set up a small workshop for the powdercoating equipment, electroplating stuff and also a nice bead/glassblasting cabinet i got as payment for welding a rocker panel on a friends car. and that in turn is gonna clear up some more room in the workshop at my parents house and we really need the space we can get because we have sourced another project there; a 1970 nova :)
i also did a lot of work at the shop since the last update, betwhen all of the engines, cylinderheads etc thats been rebuilt, i have sold off the old rotary broach i used to surface cylinderheads with because i needed something slightly more effective and with a smaller footprint so i got lucky and found a small swing surfacer from a trade school half way on the other side of the country, and stuff like this is rearly listed in the classiefieds in this country so eventough it was broken i jumped straight in the car end went to get it.
its a nice italian made piece of equipment, meant for grinding and it also has a carbide cutter made for aluminium, the head is 330mm big and the swing capacity is big enough for BMWs biggest straight sixes so its big enough for my shop.
some of the students at the school that sold it had a mishap when they moved it with a forklift and they broke the flange where the feed motor is fitted to the swing head so they sold it of rather than getting a new motor for it. wich was nice for me. :) i got a quote for a new motor and it was about 350 dollar and having paid only 700 dollar for the machine itself i figured i would rather try and fix it myself and that turned out to be quite easy, i just turned a new flange piece out of a big slab of aluminium roundstock, and i sourced a motor of a similar size and used the fan and the fan housing from that and straightened the bent motor shaft in the hydraulic press and it worked perfectly. :)
i also made a holder for CBN and PCD insert, and one holder for a regular radius insert, and bought a set of new stones for grinding. having the grinding in mind, i got a covermade out of aluminium and that turned out to be quite a task in itself because i forgot to have fittings for coolant and return made so moving it around in the shop to weld the fittings on was quite challenging but getting the cover between the stand and the machine itself was also a challenge :p moving anything big around in the shop is a pain in itself and requires a lot of planning. but with good help from my dad we got it in place. i also made a coolant system out a fuelcell, a coolant pump from the lathe i hardly used anyway, som AN fittings i had laying around and a ballvalve somebody threw in the trash. works perfectly. i also copied a fixture for heads and manifolds i found on this page and im gonna make an extension for the machine to gain height for v8 blocks.
with around a 1000 dollar invested in this machine it really has become a proper money maker for the shop :) and the results are perfect aswell, straight and with the right finnishes for different gasket materials.
P
Pogona
Hordaland, Norway
i also sold off my old Mira valve seat cutting equipment, the kit was both good and handy but i had some challenges on some heads due to the ceiling height so when i had to upgrade and get some more pilots and cutters i listed it for sale as a kit, and apparantly there is still a big demand for Mira equipment here in norway and i managed to get a nice amount of money for it. but without the money for buying new equipment right away, i had to time it perfectly so i was cutting seats on customer heads for three straight days waiting for the buyer to pick it up and i just dusted of the last set of heads before he arrived, then i closed the shop down for a trip to work and i ordered everything i needed from cylinderhead supply and had a whole new setup ready when i got home. took me nearly two days to organize the new equipment and make a nice tool rack for it but it was well worth it. :)
we have also been busy upgrading the old SF110 flowbench to a more modern standard, with data aquisition from C&D technologies / www.the-bluebox.com . my dad spent a lot of time with the computer and software installation and i have spent many days flowing and testing heads. we had som minor bumps in the road but the customer support from the bluebox is absolutely perfect and testing a set of ports now is down to minutes rather than hours. i also had help from a buddy that im rebuilding a differential for, and we had a quick brainstorming and we made a real nice valve opening fixture for the flowbench so that is just one more thing to cross off the to do list :)
i also sold off the old volvo and binned the audi because itwas time for an MOT it wouldnt have passed and i finally bought myself a proper shop car, perfect to haul engines, parts and stuff, and i had my buddy who designed my logo to put some stickers on it :) hopefully, with time, ill buy an older el camino or a pickup and make a shop truck out of that but for now the old german will do just fine :)
we also had a visit from one of the local deers :)
i also bought plasmacutter so im gonna make a cnc plasma table among many other upcoming projects, will try and update more regularly from now :)
Bib Overalls
Jonesboro, Arkansas
Good to see you posting again.
Your new house looks really good and your view of the ocean is worth a million dollars.
Having a bit of trouble figuring out where your new shop is going to be located and I wounder what the building is in your back yard. So, can you please answer the three questions that I ask in the picture below?
EDIT: Well, the red letters dont seem to be very clear son the questions are, from right to left; "NEW SHOP?", "YOU?", and "WHAT IS THIS?"
P
Pogona
Hordaland, Norway
thanks :) right you are, the new garage/shop is going to be on the left side of the house, the guy in the garden there is a buddy of mine taking pictures with his drone and the smal cabin is a 15 square meter fully insulated cabin attached to a roofed balcony that houses benches and tables and a propane grille for those nice summer nights :) the gym equipment is going from the room in the garage there close to thegarden and into the cabin for now and hopefully we will use it more :)
Boosted1
Georgetown, KY
Congrats on your new home.
It has great view.
Also nice job on the grinding machine. That turned out very good.
Mike.ASC
East coast
That's a nice property you have there with a great view. Good utilization of your workspace and nice improvements. Congrats on your machinery acquisitions.
slik560
Kansas, USA
Late to this thread. Very impressive. My wife still has family in Bergen and the surrounding area. She wants to visit there some day. Both her mom's parents were from Norway...first generation. :)
drivesitfar
POGONA: i'm guessing you don't let your feet hit the ground without running most days. nice pictures and looks like you found a new spot. i was thinking you might outgrow the original place you started posting with cause you had a ton of stuff in there. since you didn't move it over to your house do you still own the other house or was that a commercial shop you own that you were posting pictures of before?
in any case looks like you've been busy and for a good reason. i'm not sure you can get some of our gym equipment over here in your area, but if you can find a VERSACLIMBER a rack of dumbbells and a weight bench it might be all the gym equipment any home would need. i've helped a lot of people set up full on gyms and very few get used, but the guys and gals using their VERSACLIMBERS seem to use them daily and are in great shape.
cheers and WELCOME BACK
P
Pogona
Hordaland, Norway
Yes its been a hell of a year, also been busy as a mechanic for a 2600cc S&S powered harley dragbike last year so i really tried my better half's patience. :)
The shop is still in its original place in my parents basement and most of it is staying for as long as im welcome sponge on their eletrical bill ��
The new shop at home is a long term project and the plan is to build it in small steps as the funds allows for it. We spent a lot of money for a slot in a new boatyard just next to the pier below our house last year to so that money went straight out of the garage budget. But we are still young so if it takes 2 or 4 years to build a new workshop at home it doesnt matter. :)
I have a couple of sheet metal machines and tools that i need some room for as well so its gonna be nice to have an additional shop for metal projects too :)
P
Pogona
Hordaland, Norway
Give me a shout if you ever get to visit bergen :) my shop is just a ferry ride and an hours drive away from bergen. :) nice place, famous for all the rain 😂 im actually travelling to bergen tomorrow morning, catching a plane from bergen to france, then congo-africa. Looking forward to some sun and time off from all the work at home :)
drivesitfar
Pogona: forgive me for asking this, but you have so much talent in your machine shop and those engine builds what sort of job in Africa would be worth your time? or is it more for the ADVENTURE?
i was going to ask if you had waterfront access. WELL DONE!!
do you own a boat yet or are you building one?
P
Pogona
Hordaland, Norway
With bills to pay i have to have a steady income, i work as a Rov pilot/tech and my trade certificate says electrician. I have allways had an interest for cars and engines and have always wanted to be self sufficient when it came to machining work so one can say that everything i do in the shop is just a hobby that got out of hand 😂 for now i couldnt afford living off of it because the market for the work i do here is very season dependent and i really dont think i would find it as fun i knew i had to do it, and it is easier to do a good job when you do it because you want to rather than have to so for now i just appreciate that i still have a job to pay the bills and can have the other one as a hobby. 😊
We dont have a boat yet but we'll probably buy a small one closer to the summer so we can explore the area around us and do some fishing, i would really like to build a chris craft inspired runabout one day with a 1990s Bmw or jaguar v12 engine but thats gonna have to be some time when i wake up one day and realize i dont have anything to do 😂😂
RhysBud
QLD, Australia
Great thread. I've really enjoyed the read and look forward to future updates. Also, its great to see you guys enjoy Somersby on the other side of the world too!
