coachrick
So, I'm working in the garage a bit and decide to replace a GFCI outlet that is a little too touchy(after 10 years). In front of the chest high outlet is my converted mule chest(dresser) and it must be moved. Reasonably smart guy that I am, I installed plate casters on the four corners after reinforcing the legs of the chest. We moved here three years ago and I've moved the chest a time or two but essentially it stays in place.
Here's the fun part:
Two of the four casters have brakes and as I began to "try" to move the chest, I checked to make sure the brakes were not engaged(flat floor, no need for brakes). Also made sure the wheels were turned in the 'right' direction so the cabinet would roll easily. Dang!!! Thing acts like the brakes are on or the cabinet is fully loaded(not loaded...that's part of the garage project...maybe 1/3 loaded with odds and ends, not heavy tools). I pull a bit more, careful not to tug on the top of the cabinet, lest I manage to topple it over onto my person. It's moving, but barely.
I inspect the wheels more closely and discover the 'rubber/plastic' "tires" are disintegrating!!! I don't see the 'remnants' of the tires at first since they are under the cabinet, leaving a trail of rubber-ish debris. It seems the "rims" of the wheels are holding up but the cabinet is tilting precariously. I manage to drag the cabinet enough to destroy the 'tires' on all four corners somewhat symmetrically and manage to get the cabinet out of the way of the outlet and service panel. I go about my electrical duties while I ponder the next step with the casters...Dang!!!
I managed to get the chest back into position; but now I must unload it and re-install some sort of casters...again. I got these originally at Northern and they were of moderate price($25 for 4 ?) and load rating(250# ea?). Do I need to spend MUCH more to get some wheels that will hold up? The garage normally hits 90F on our hottest days; but I have seen it go to 94F when both vehicles have been pulled in and doors closed. I've never seen it below 50 degrees, even in the coldest weather. The floor is concrete but has a decent sealer from years ago. Fortunately, the NSF shelving I have used in basements or garages for over a decade has 4" stem casters that have held up to the elements...no failures in any of the half dozen garage units.
I'd rather stick with 3" wheels and something that will roll smoothly without damaging the floor.
Any thoughts on the best wheels for the job...or any I should avoid(like the ones on there now!)?
I'm old enough that I thought I knew some stuff; but I reckon I didn't know I had to worry about fairly stout casters disintegrating in the garage!!!
Thanks for reading my story!!!
