Rosco
I have aprox. 23 Non-IC can lights in my house. Not only does this cause energy loss, but my attic is also insulated with cellulose insulation which I believe is causing a dust issue.
My question is, do I need to change all of the Non-IC housings to IC, or can I do an led retrofit (less heat and energy, plus sealed)? I know the project will be a little costly, I can do the work myself, just wondering from the pro's what my options are.
If I change the housings I will be able to seal and insulate over the top. I changed 1 as a trial run using an air-tight IC housing and I still had to use a little spray foam around the housing to sheetrock transition as there were still small gaps. Is the spray foam a no-no in this area?
Sorry for the long questions, just wanting advice, tips etc. before going any further.
