Not so poor man's lathe
BrianHayes
North Carolina
When I was restoring my Craftsman bench top 100 DP, I took advantage of a little-used Ridgid lathe to sand and polish the column.
It spins a little too fast, but I was able to get a good result without damaging myself, the equipment or the column.
No that I'm restoring a floor model 150 drill press, I have a problem: a 62" column won't fit on a 36" lathe bed, or will it...
I removed the tailstock from the lathe, built an extension table, and built a tailstock that mounted directly to the extension table.
This worked well for a while, but I noticed the quill was starting to back out of the tailstock, which shouldn't have come as a surprise since the quill was only friction fit into a hole in the tailstock.
I secure it better tomorrow, but I consider this a successful proof of concept.
MushCreek
Upstate South Carolina
I had to drill and tap some 10 foot long rods. I used a piece of pipe and a couple stands to support the things while I (carefully!) machined them on my lathe. You make do with what you have.
Roberts210
Missouri
Good job! I once made a "lathe" to turn and sand 8 foot long octagonal beams for a large tapestry loom a lady ordered from me. The beams were glued up from straight, clear, 2X8 material, then chamfered heavily on a table saw, and sanded on the lathe. Only used it once, but it paid for itself since I made it on the cheap.
Internally gripped by the chuck would be my guess
I have one like this, which can use the outside jaw edge to grip a vessel’si terror rim.
whateg01
doo dah, kansas, usa
Or just use a metal lathe to do this which would probably be much safer.
Not many people have a lathe of any type long enough to safely do that unless you are just using a steady rest, which I've done. A 150 column in a 10x30" lathe. I would have preferred putting it between centers.
Maui
Upstate NY
You may have missed the word 'poor' in the thread title. A metal lathe capable of turning a 62" tube would be cost-prohibitive. The challenge is to make do with what you have.
No, it isn’t cost prohibitive. I have several metal lathes that I’ve used over the years to do EXACTY the same thing. The Logan metal lathe I presently use for this purpose cost me $300. With a steady rest in place, setting up a column for polishing like this is quite easy on a metal lathe. But you need to be able to align it very accurately. A metal lathe allows you to do this. A wood lathe, not so much. If you don’t align it accurately enough the column will gradually pull out of the chuck jaws as you proceed to polish it, and this is where safety could become a concern in using a wood lathe to do this. Please know that I’m not bashing the OP for his set-up. What he did is quite clever. I’m just voicing what I know to be a potential problem in doing this.
whateg01
... A metal lathe allows you to do this. A wood lathe, not so much. If you don’t align it accurately enough the column will gradually pull out of the chuck jaws as you proceed to polish it, and this is where safety could become a concern in using a wood lathe to do this. Please know that I’m not bashing the OP for his set-up. What he did is quite clever. I’m just voicing what I know to be a potential problem in doing this.
He has a dead center in the tail end. It's not going anywhere. And that's why a live/dead center is a better way overall for doing this than a rest. I would hazard a guess that over half of the hobbyists that have a metal lathe in their garage or basement don't have a steady rest anyway.
BrianHayes
North Carolina
...But you need to be able to align it very accurately. A metal lathe allows you to do this. A wood lathe, not so much. If you don’t align it accurately enough the column will gradually pull out of the chuck jaws as you proceed to polish it, and this is where safety could become a concern in using a wood lathe to do this....
I did take that into consideration, and spent a good deal of time aligning it with a laser level and playing card shims.
I saw the potential for slip at the chuck, and added the dead center as a precaution.
I would love to own a metal lathe with this capacity (or any capacity), but for now, I'm making do.
