Not sure where to put this. Block building paint question
poorboy87
Southern Indiana
Mods can move this if it's in the wrong area.
I've got an old block building that wicks moisture in really bad.
Is there something I could paint it with? I've seen basement paint that is for moisture control but I'm not sure. Should I do both sides inside and out?
Outside wall
Inside wall
First, let the block dry out. No paint will stick to something damp.
Get a primer that is specifically for masonry/block. The first coat is the worst, trying to work paint into all of the pores. A good airless sprayer works well for this or roll with a long nap roller. Use a brush where necessary to force paint into all the little nooks.
Finish coat can be any good quality paint. Don't do the inside until a couple of weeks after the exterior.
LegacyIndustrial
deerfield, IL
Right on. I believe they call the first coat "block filler".
Sent from my iPad using Tapatalk HD
P
poorboy87
Southern Indiana
Ill post up in the gallery before too long. Still gathering stuff for the wiring.
I'll check that primer out.
Think I should pressure wash the outside first?
Thanks for the info guys!
It wouldn't hurt, but that will add a couple of days of drying before you can start priming.
