Not your average tool tools
Whatsit
I have been rebuilding a motorcycle thru this spring and summer, and now that it is complete (and fun as hell to ride) this winter I plan to tear it down and turn it to a Cafe Racer style bike.
What I have noticed is that outside of a basic semi expanded Craftsman 100 pc tool kit, the tools I needed, have all been odd **** that I did not know there were specific tools for.
Now granted, when I started working on this bike I had no idea what I was doing, but this is how I learn. I learned a **** load.
Seal pullers, compresison testers, mulitmeters, and chainbreakers just to name a few of the tools I have become familar with. Most of these are not just haning out at your local Sears Craftsman center. I though it would be neat to start a thread and list tools that you did not know exsited until you needed them.
PAToyota
South Central Pennsylvania, USA
I've been reading Roger Welsch's tractor books for years (search on Amazon). His latest one is "From Tinkering to Torquing - A Beginner's Guide to Tractors and Tools."
I love his books and his sense of humor. This book wasn't quite as good as the others because a lot of it is just descriptions of tools for someone who may not have spent their whole life hanging around various shops. But even I picked up some information I hadn't known before.
kartracer55
Your exactly right. I get PM's here and there asking for suggestions on building up a basic toolkit because somebody wants to start a certain project, but I always mention that its impossible to make a complete list.
For example, I have run into the need for some oddball tools that, as you say, you will not find hanging up in sears and many of the employees at sears probable dont even know what they are...
Granted, some of us improvise... for example, a seal puller is nice (kinda scary looking actually) but alot of times you can just use a sharp pick or an awl and puncture them and pull them out. Granted, its a bit on the crude side but it will work in a jam.
List eh? This may be a good thread. Edit the title to say "tools you need but nobody tells you about" or something like that and Ill stick it in the sticky up top. Good idea!
So heres what ive got....
Stethoscope- Great for pinpointing odd noises. You can actually use a short piece of tube but the stethoscope works much better <$25
Small metal ball (like from a ball bearing, maybe 1/4'' diameter)- oldschool machinist's trick for measuring the wall thickness of round objects with a flat faced micrometer. Use a dab of heavy grease to hold it in place.
Tapered Hand reamer- My number 1!!! This is one damn handy tool for when things dont quite fit. I use this so often you wouldnt believe. Its REALLY great for drilling materials like thin rubber sheet or delrin because these materials tend to stretch a it when drilled leaving a hole undersized a bit. Great for aligning sheetmetal holes. Everybody should have at least one of these (Ive got two)
Ill edit this with more later on, I know ill think of a few more
Great thread
Jim
eschoendorff
where'd you get yours? Any suggestions on what to get?
W
Whatsit
Here's some more:
-Turkey Baster with a Hose on the End (great for putting oil in cylinders)
-Magnet on a stick (when your loose your nuts)
-Thin Bendy light
-Impact Driver
I have tried the hook or pick thing for removing seals. But the Seal remover is the deal.
kartracer55
Ed, I dont know where the first one came from, my dad got it. It's branded "ace"
The one I currently use I got new for like 15-20$ at the englishtown swapmeet. No brand ID, just Black oxide stamped "USA". A guy had a whole bunch of them.
Search MSC number...
02058774 for US made
02059301 for Import
Jim
JohnHenrys48
Arizona
As good a place as any to resurrect this...sorry...:willy_nil
Tool Definitions:
1. DRILL PRESS: A tall upright machine useful for suddenly snatching
flat metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, splattering it against that
freshly painted part you were drying.
2. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you
to say, "SH**!!!"
3. ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
4. PLIERS: Used to round off hexagonal bolt heads.
5. HACKSAW: One of a family of cutting tools built on the Ouija board
principle: It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
6. VISE GRIP PLIERS: Used to round off bolt heads. If nothing else
is available, they can also be used to transfer intense welding heat
to the palm of your hand.
7. OXYACETYLENE TORCH: Used almost entirely for setting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside a wheel hub you're trying to get the bearing race out of.
8. WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2 socket you've been searching for the last 15 minutes.
9. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground after you have installed your new disk brake pads, trapping
the jack handle firmly under the bumper.
10. EIGHT-FOOT LONG DOUGLAS FIR 4X4: Used to attempt to lever an
automobile upward off a hydraulic jack handle.
11. TWEEZERS: A tool for removing splinters of wood, especially
Douglas fir.
12. TELEPHONE: Tool for calling your neighbor to see if he has
another hydraulic floor jack.
13. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool
for spreading mayonnaise; used mainly for removing dog feces from
your boots.
14. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
holes and is ten times harder than any known drill bit.
15. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
tensile strength of bolts and fuel lines you forgot to disconnect.
16. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying
tool that inexplicably has an accurately machined screwdriver tip on
the end without the handle.
17. AVIATION METAL SNIPS: See hacksaw.
18. TROUBLE LIGHT: The home builder's own tanning booth. Sometimes
called a drop light, it is a good source of vitamin D, "the sunshine
vitamin", which is not otherwise found under cars at night. Health
benefits aside, its main purpose is to consume 40-watt light bulbs at
about the same rate that 105-mm howitzer shells might be used during,
say, the first few hours of the Battle of the Bulge. More often dark
than light, its name is somewhat misleading.
19. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and squirt oil on your shirt; can also be
used, as the name implies, to round off the interiors of Phillips
screw heads.
20. AIR COMPRESSOR: A machine that takes energy produced in a coal-
burning power plant 200 miles away and transforms it into compressed
air that travels by hose to a Pneumatic impact wrench that grips
rusty bolts last tightened 70 years ago by someone at Ford, and
rounds them off.
21. PRY BAR: A tool used to crumple the metal surrounding that clip
or bracket you needed to remove in order to replace a 50 cent part.
22. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
23. HAMMER: Originally employed as a weapon of war, the hammer now-a-
days is used as a kind of divining rod to locate expensive parts not
far from the object we are trying to hit.
24. MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on boxes containing upholstered items, chrome-plated metal, and
plastic parts.
