NP241D Transfer case filler plug removal
Dodgebaby
Needing an 8pt male wrench, 10mm? To remove filler/drain plugs in transfer case. 96 Dodge 4WD 2500 5.9 12V Cummins. Thanks
purplezr2
Central MN
Are you sure it doesn't take a 3/8 ratchet?
Also make sure you can remove the fill plug before draining it.
JBradley500
I agree with the post above, especially removing the fill plug first. You make that mistake once and you remember forever.
L.Cheapo
The corners look to be more than 90*. Not sure if that'd be a good idea to use a 4 point tool in there, especially if it's been in there since 1996. Can you get a socket over the external hex of the plug?
Odd, as my 98 has an allen plug.
MW.
From the picture it looks like a hex on the outside?
DTE
North Carolina
Over the years I have made tools to do what you are doing by finding a bolt head that fits the plug and then putting a nut on the bolt weld it up and you have a new tool. Fixed several different ones over the years for different transmissions and transfer cases.
shockwave
Marietta,ga
it looks like an 8 point male internal and probably a 24mm or 15/16 external hex you can use either
i just use the external hex on these you should be able to get a short socket on there
