NPS & NPT.......?
Crow Horse
Southern Tier, NY
I'm currently looking at detail spray guns to clear coat my carved wood signs. I've noticed that the air inlet on the guns I've seen online are 1/4"NPS and my air hose is 1/4"NPT. I understand I'm looking at tapered & straight threads but in all the reviews I've read about various models, nothing is mentioned about this. Is it ok to use them together?
Firebrick43
West central Indiana
You shouldn't, but with plenty of teflon tape it works normally. But why not put the ****** directly on the gun. They are available with in NPS with an oring seal.
Walkers
Cave Creek Az
NPT works just fine in them, just don’t overtighten. I have a 1/4” NPT tap that I run in them to clean it up a wee bit, but it seems to work without it too.
Walkers
Cave Creek Az
They make an NPS to NPT adapter for exactly this application. Why do it half-fast? In my case, I actually used a mini gauge/regulator from my spray gun manufacturer that also did the NPS-to-NPT conversion.
The reason I do it is to eliminate overhang from the bottom of the gun. I regulate and dry my air at the wall, and commonly paint large items that are sitting on stickers on the ground, so need to get the gun low.
PCustoms
VT
Harbor freight?
Years ago I had a cheap gun that looked like that. Pretty sure s male QD connection screwed right in with a bit of Teflon tape. I might have had a small water separator or regulator there too, so long ago I forget.
dnschmidt
Phoenix, AZ
It's really not a problem at all. All spray guns use the straight thread that you're showing it's normal, not anything special. You can put a 1/4 NPT female air line ****** over the straight thread just use a little Teflon tape on the mail straight fitting. I use spray gun regulators on my guns (RTI MR-1) which take care of this problem automatically but the cost of these regulators is more than you paid for that gun. It worked on your daddy's Binks and it will work on any spray gun made. People have done it this way for 50+ years.
C
Crow Horse
Southern Tier, NY
If it'll work without any issues, then I should be good to go using a 1/4 NPT hose. It just seems odd that this mismatch is an acceptable industry "standard". Thanks for everyone's input!
I'm still scratching my head as to why there's NPT, IPT, & IPS.....
RAYJAY
UNION DALE PA
This would work if a female to female adapter is used. I haven't been able to find a female NPS to male NPT adapter yet.
why female to female ?? go from post 13 should always run a regulator at the spray gun, then a male or female snap fitting perfaable full bore
joe_padavano
Northern VA
Better practice is to regulate at the gun to account for loss in the hose.
Walkers
Cave Creek Az
I just used a gauge at the gun to check my wall regulator was providing the right gun pressure at flow then removed it. I have been using the same guns for many years and can tell if they need a minor adjustment pretty well by now.
