nut drivers
_brian_
Wisconsin, USA
My query is to get the opinion on nut drivers and their use. I have an old USA Craftsman set that came with my first tool set many years ago. They all look new. I like the idea of them, but looking at my usage, it seems I just use sockets instead. Thinking about it, this allows me to use extensions, swivels, etc whereas the nut driver is another tool I need to pull out of my box with a somewhat limited use.
How do others use these? Is there an advantage to them I might not realize? A common response I have heard is applications like hose clamps. For those, I just use a socket with the appropriate extension with a spinner on the end, so I can use a ratchet if needed then finish it quickly by hand.
vjquan
Low torque applications. I think I used 2 out of the 14 I had. Sometimes the hollow shaft is nice. You can get away with a spinner handle and effectively have the same thing. I ended up selling them because it took up a lot of space in the tool box. I'll buy individual sizes as needed if I really miss them, but so far I haven't.
Jacobs976
Indiana
I've never used mine but I've heard electricians use them more often than mechanics or anybody else. Good for low torque applications because you'll have a hard time over torquing with a screwdriver handle. Plus they don't fall apart if you accidentally catch the end on something so they're less risk working with live wires. See alot of the insulated handle ones more than standard for them too, can't short anything out if there's no metal touching other than the nut or bolt to the tool opening.
CoogarXR
I use mine frequently in electronics repair. They are thinner than a spinner + socket, and the socket head is usually shorter. I have full hollow shaft nutdrivers and magnetic ones, and I use them both, sometimes on the same nut. I'll use the magnetic to start the nut, then the hollow to sink it.
Electronics work can be very cramped, so that couple-millimeter difference between a nutdriver and a socket+spinner can make all the difference.
I rarely use them in mechanic work though, other than maybe hose clamps, and those weird hex-torx ford interior screws.
lilredex
Toronto
I use the cheapies mostly, for driving self drilling sheet metal screws in a drill. Go full speed then back off when they break through....works every time. Save my good sockets for the real work.
KnurledNut
n/a
Magnetic hollow shaft nutdrivers can be super handy for mechanical/electrical work. I use 1/4 and 5/16 often.
alien
I am a retired commercial and industrial electrician of 40 years. We routinely used nut drivers in the electrical trade. They are being replaced with the multi screwdrivers these days. 1/4, 5/16, and 7/16 were the most used sizes With 3/8ths occasionally.
sparky 1971
Central Iowa
I use nut drivers almost daily on the job, but never at home in the shop. I had a set at home, but I think I gave them away. I do occasionally use the 1/4" spinner handle with a socket on it though when I'm tinkering on something home related.
ChevyEFI
Phoenix, AZ
CTA Tools 1100 flex drivers cover hose clamps pretty darn well.
My screwdriver style nut drivers are very well behaved and sit quietly for years on end.
I think there's a driver handle (maybe wiha?) that accepts power drive bits. Malco offers them. That plus a Malco flip-socket driver (several lengths) could cover 1/4 through 3/8. Dewalt has a couple flip versions to cover 1/4 through 7/16 (short only) and Klein has a 6-sizes multi-tool (long style) power bit. These combine well with a driver tool. In HVAC, you'll use your driver way more than a manual handle, for example.
Fedwrench
Valley of the sun
My nut drivers gather dust. :lol: I used to use them quite a bit back in the day but, constant tension wide band hose clamps and small cordless impact drivers have them not seeing much use these days. I mostly use nut setters on a small snap on CT751 (i think, the labeling is worn off and it's just an old scratched up hunk of black plastic now). I like it because it's the smallest impact driver I've ever found. Not the most powerful but, for air inlet tubing, trim and dash work, it's hard to beat. You can get nut setters in different lengths, and magnetic/non magnetic too :beer:
bobg03
conway sc
I used 'em a lot pm'ing freezers and ice machines, hadn't touched one since 2005. My brother has them now, I liked my Kliens
Kscardsfan
The Little Apple
I’ve found a few applications on small engines where they were pretty handy to have around. Like others said, a few times on home repair jobs with plumbing and electrical work. But I don’t know if I have ever used them on automotive repair jobs in my lifetime.
dscheidt
My first memories of fixing stuff are helping my dad fix appliances and plumbing stuff around the house. It always involved three things, a flaming hot trouble light with an incandescent bulb in it, yelling that I wasn't holding the trouble light the right way, and a set of color-coded craftsman nut drivers, in a vinyl envelope. I have those nut drivers, and use them when I have to fix the dishwasher or something. those trouble lights, on the other hand, I do not miss.
Other than that, nut drivers are great for small low torque screws, and for self-drilling and self-tapping screws, because you can easily put a lot of thrust force on the fastener while you turn it. a nutsetter on a drill or impact driver is faster, and has probably replaced most professional uses of them for that.
SRSemenza
I like them for things that don't need a ratchet and also when there is a nut on one side of something and a screw head on the other. Such as machine screws. Used a nut driver with a slotted screw driver today.
I prefer them to sockets attached to a screwdriver style spinner handle, in the same way that I prefer a "one piece" screwdriver to a multi-bit driver. Just has a better feel to me.
Seth
4xdog
Santa Fe, NM
I failed to mention that mine are not the hollow shaft style. This is what I have...
I have a set of those Craftsman nut drivers too. They're drilled about 1" deep. Useful enough much of the time, but not for everything one runs across.
Nutria
Eastern Sierra
Many years ago, I viewed nut drivers as an answer to a question that no one asked, but I've been using them more and more as time has gone by. I use them almost daily now. As others mentioned, they are perfect for low-torque applications; I have a set in the rollaway and another on the pegboard.
Buster21
Idaho
I use mine a lot because I grew up using them. My dad was an old fashioned tv repair man and electronics technician. He had a set of xcelites that were probably the most used tool in his tool box, especially the red 1/4" taking off the backs of tv's. They were stored in the fold out wings of his xcelite tool case. I currently have craftsman but prefer my rubber handled Kleins.
Xcursion88
I'd say if you were working around tedious things that dare not be scratched or over torqued...they have their place.
It's really a tiny window where they'd be preferred over regular sockets and ratchets and or ratcheting wrenches etc.
Davefr
OR
Nut drivers are a "must have" tool for me.
- The thin socket wall gets into tight areas that a socket won't fit
- The hollow shaft will remove the nut on long studs
- For torque sensitive applications, you have more feel
- The handle is more compact then a ratchet if you don't have room for swing
- The smaller ones come in increments of 1/32" and .5mm
- Magnetic ones will hold the screw
- Saves time over configuring a ratchet, socket and any needed adapter
Electronics/electrical, HVAC, appliance, OPE, automotive (life savers working under a dashboard)
This little set and it's metric equivalent have saved my **** many times when no other tool would fit.
Bubba Fett
Eastern NC
I have a few sets from Klein, Masterforce, Husky, Companion, and a few that came with PC/electronics tool kits. They are really popular among electronics repair techs, as well as electricians and HVAC techs. It's easier to grab the driver you need than it is to find the correct socket.
There are a lot of multi-tip nut drivers, but I prefer individual ones, since they are easier to select and use with one hand, and the x-in-1 nut drivers tend to be heavy and bulky. Sometimes that one 7-in-1 nut driver is heavier than 7 individual nut drivers. I also like 10-in-1 and 11-in-1 screwdrivers, but rarely use the nut drivers unless that's all I have on me.
Good ones (Klein, Vaco) have hollow shafts, which allow you to reach nuts that threaded onto longer fasteners. You could use a nut driver to hold the nut in place while tightening the fastener with another nut driver, spinner handle/socket, ratchet, etc. Magnetic nut drivers are nice, but the socket is shallow. I prefer to think of them as nut setters, since they work great with machine screws.
Luciferi
I use 7, 8, and 10mm almost daily. I have older craftsman with the color coded rubber handles, super easy to find orange, yellow, and blue. Great for most auto interior work where you care about not stripping stuff out. It is also great for telling if some idiot has been there before and over tightened everything.
I also have a couple of black Klein in odd sizes that blend in on my tool cart and have to search for. These are hardly used, mostly thinking they are screwdrivers and forget I have them.
j3rf
One of these works well for my uses. Much smaller to keep around than a whole set of nut drivers.
I went years without one, then needed one to hang a set of blinds. Couldn't get anything in there close enough to the wall, no power screwdrivers or drills fit, my sockets were all a long way away. I bought a single nutdriver, 1/4". The only other thing it got used for was attaching the dryer duct hosing in an awkward location. And occasionally holding driver bits
Thanks to you bad influences, I now have a very thorough harlequin set, picked up cheap, but never used yet.
KnurledNut
n/a
@Davefr
I’ll add another to your list:
Ya don’t have to worry about knocking the socket off into the abyss or it getting stuck on the fastener as you do with spinner handles.
lardy1
Another one of those things that I'm sure I could get by without. But when I do use them I'm always pleased that they are there.
I use sockets on a ratcheting screwdriver way more than I ever thought I would.
Mechanical Noise
Southeast of O'Hare
They were really handy for working on old school TVs and radios that were held together with dozens of hex head screws. I wore out a 1/4" Xcelite driver on those things. Probably wore out a Vaco, too but I didn't replace that one and it's been a long time. The advantage of nut drivers in that sort of work is that there's only a few sizes typically needed but changing between individual sockets is considerably slower. That, and the brightly colored handles make it easy to grab the right driver the first time. And, as mentioned, there's no risk that a socket will snag on something, pull off the drive, and fall into the bowels of the project.
More modern stuff is usually some sort of snap together plastic or held together with phillips type screws.
