Nut Splitters?
4x4gearhead
New Hampshire
Has anyone ever gotten a nut splitter to actually work? I had a couple given to me by my best friends father. Ive tried to use them here and there but with no success. I dont want to get rid of them as my friends father has since passed. I did a search but to no real success. Do the hydraulic porta power style ones work?
lotsoftools
Inland Empire
You know, I can't say for sure if I've ever used it on a grade 8 nut. It definitely works on grade 5 and lower though.
5lima30
Mountains of Western NC
I have a couple of HF ones that I have used several times on farm implements that worked fine. Don't use them often but they did the job. JMHO.
rsanter
visalia ca
They are a tool of last resort...
I have a couple I bought years ago that are asian in origin and they have worked great
Bob
I have a snap-on and a K-D and both work well, however the Snap-On is easier to fit, (slightly less bulky).
If you are having issue keeping it square, make sure the "anvil" rotates easily and has some lube in there, as it needs to rotate freely in the clamping screw.
pipsters
USA
All nut splitters, no matter the kind, always need lots of lube.
4x4gearhead
New Hampshire
I was thinking of maybe dropping a bit of coin on a real name brand one, sometimes it would be nice to have out there on the road. As I always say when everyone asks me why I have so much **** packed into my service van, it's good to have options, thanks for your input guys.
BMEdoc
Richmond, VA
I've used a fairly cheap one to split many, many nuts. That single tool has saved me countless hours and effort when disassembling my Packard.
Just lube it well, and keep the point sharp.
teletekman
Madera, CA
Well my nut splitter works but most of the time it's a bit hard and confusing to figure out. You read the manual but as always offers me no help. Aparently there is no damn phone number to call for tech support and being that it's already past it's warranty period it would cost me too damn much to pay the restocking fee. It does work quite well however when the weekend comes around for some reason.
Murphy4570
West Deptford NJ
What is the exact point of nut splitters? I use a cutting torch. Heat problem nut up, and it usually comes off with no problems. Are they for use in lieu of a torch?
Enough heat to get a nut broke off and you'd best toss the bolt/stud as well. A nut splitter allows the removal of a problem nut without destroying the fastener it's on.
Manco
I have one of the relatively inexpensive Craftsman nut splitters. It will take up to a 3/4 nut. However the main probably I almost always have is that I can't get the dern thing to fit over the nut due to the available space around the nut. When I have lots of space it works fine. The rest of the time I either use my sharpest chisel or heat, depending on the situation. With a bit of care, the bolt or stud is usually fine.
diggerrick
My HF one broke the first time I used it. Antiseize probably wasn't the best thread lube. I noticed mine had a sharp vee thread profile - terrible for the application. Maybe they're different now.
MarkJ
We must have the same model because I've also run into the space issue. When it works though it's a life saver.
