Not disagreeing, but I'm curious what the reasons are. Why exactly 8" and why not angled head?You want 8” cutters.. not 7”, not 9”. You dont want an angled head.
8” gives the best combo of size vs leverage, IMHO, and belive me, ive tried experimenting. Its basically the sweet spot of having handles long enough that will maximize how much your hand will comfortably open and close. If you go bigger, say 10”, youll find you’ll wind up holding the handles in the same spot as an 8” pair. If you go smaller, youll find yourself holding the handles at the very edge, and having to use more strength to cut hard stuff cause you lost some leverage with the shorter handles.
Here are a couple examples of the poor finish on some of the NWS pliers. The gritty looking stuff is actually a solid part of the surface finish, not grimy buildup or anything like that. You can also see unevenness near the cutting tips on the end cutters.
Sent from my Pixel 2 using The Garage Journal mobile app
Of course the problem is, if the coating isn't even, it can cause the pliers not to open and close smoothly, and it doesn't prevent rust in the areas it doesn't cover, and the protrusions in the coating cause it to flake off as it hits or rubs against things, then it's probably not the best rust prevention method for a pair of pliers.Yea to be clear -whats he’s talking about is just the coating on the metal. Not the metal itself. The reason you dont get this on other pliers, is because other pliers dont have a coating like this. Its purely cosmetic. To make them perfect would be like finishing a finish coat. If it keeps them from getting rusty - IMO its absolutely worth it. I love my NWS stuff.
Grip On is another company that comes to mind which gives their pliers an epoxy coating for rust prevention, and they do a much better job in my opinion.
Sent from my Pixel 2 using Tapatalk
Right, but really, what area’s aren’t covered? The working edge of the tools? Consider many other well known pliers employ “use” as rust prevention..
I dont own 50 pliers from NWS, but every one i do have is great quality. The Irwin branded NWS lineman pliers feel like theres a damn ball bearing in the joint. The fact i dont like the bulky grips is just a personal choice.
I don’t think rebranded tools should represent a company as NWS. Only if the NWS branded tools had that finish. It is like comparing TEQ to Gearwrench. TEQ is rebranded Tools for advanced auto. All my knipex and NWS tools withstand whatever beatings they suffer through my work day. I don’t have chrome finishes on them just the black finish.
Those areas with the rough finish inside the joints have spotty coverage. You can see it a little in the bottom pliers just to the left of the rough finish there's an area that's lighter colored where the coating doesn't complete cover.
I wish my Irwin branded NWS pliers felt like they had ball bearings in the joint. They don't though. They feel more like they have grit in the joint. which is why I've hardly ever used them. I've not yet been able to fix them.
That's an interesting point. I have a bunch of Irwin rebranded NWS and a few Felo rebranded NWS, and none are that impressive. But I also have a couple actual NWS branded pliers which happen to be pretty nice.
On the other hand, I have some Craftsman branded Knipex which are great.
For what it's worth, I like my NWS pliers, so I'm not really complaining, but that's not a great analogy. It'd be a good analogy only if the normal mode of operation for a vehicle was to drive around half the time with the hood open. If that were the case, then I think one of the vehicles having a poor finish under the hood would be a valid complaint.This is "normal" for the Fantastico type pliers as that part is hidden during coating. My chrome plated fantasticos have a similar issue where there's almost no plating there. All my others have excellent uniform plating. This is kind of like a BMW vs Mercedes discussion where one guy says the underside of the hood wasnt clearcoated. I have pliers by both and like both equally. I have a few NWS where the hinge was looser than I like and a Knipex where it was too tight - thats a fine line to balance. My only real Knipex complaint was a pair of bent tip needle nose that was garbage - tip alignment was terrible. NWS really shines here. I dont need any more pliers, but I wish NWS would expand their pliers offering instead of rebranding every tool known to man, and even wiring terminals
