O Ring assortment's that don't ****?
dkmc
NYS--Upstate in the corn fields
So I've figured out like many others that the Harbor Freight O ring assortments absolutely ****. The cross sections are thinner than standard and the rubber
is some sort of material that nearly dissolves in oil. So the question is, where does one find quality O ring assortments that are the correct sizes and made
of real Viaton or Bunna-N material that lasts? I see plenty of kits on EBAY but they all look similar to the HF ones.
kelpaso1
MEMBER EMERITUS
New Brunswick
That's what you get when you buy from HF. Junk made in China. Stuff like that I would get from NAPA and made in USA.
D
dkmc
Just got back from the local bearing supplier. They have assortments, same problem. Then I went to the NAPA store. SAME PROBLEM. Their set is in a NAPA box but the O rings look like the same China stuff from HF. So your idea that NAPA has made in USA stuff is a joke.
D
dkmc
Thanks for the links. I was on MC checking out the assortments but I am leery they will have the same problems stated above. For starters I guess I'd have to verify they are made in USA to correct specifications.
DerekV
Central TX
No problem. Looks like a lot of the sets are made in PRC, but generally speaking McMaster doesn’t sell junk. If it has a spec, you can guarantee it’s made to that spec. Lots if their customers have stringent quality requirements, something to keep in mind.
kelpaso1
MEMBER EMERITUS
New Brunswick
Just because they LOOK the same doesn't mean they are.
D
dkmc
When I say they are undersize in cross section that is exactly what I meant.
You don't know who you're talking to. I'm a self employed engineer/designer/machinist/welder fabricator.....44 years. I took dial calipers with me and MEASURED the O rings. They are .005 to .007 (that's Thousandths of an inch) undersize.
D
dkmc
The one assortment shown on their (MC) website looks like the exact same plastic box as the HF set. And also the exact same box as the one at the bearing supply house I visited. The HF box is red. The one at the bearing supplier was blue. NAPA's box was white with the NAPA logo. All the same O rings. The critical outcome of this is, these O rings would be completely useless and won't seal. There are complaints of them being too small to seal on the HF website. Useless.
Here is the set, looks identical to the HF set. HF price is $8-ish. MC price....$45!
tdkkart
Eastern Iowa
China is very good at making things, even plastic boxes, look just like stuff made in the US and other places. That's where they start.
DerekV
Central TX
Eh, you can’t always assume the quasi-illustrated photo you see for their products is exactly what you’re going to get.
They ship fast and have top tier CS. Not a whole ton of risk ordering a set and sending it back if the sizing isn’t up to snuff. I’d probably give them a quick call first to see if that’d be ok, assuming they come shrink wrapped, etc.
D
dkmc
This one is USA-made.
Thanks for that link. It's a tough choice, I need quantity 2 -006 O rings. Buying a $150 set to get them of the correct size is an interesting choice.
DerekV
Central TX
There’s a huge difference between HF and McMaster-Carr. One has a reputation built on quality and standards, and the other…haha…does not.
Two questions to ask yourself:
1) How are those $8 sets working out for you?
2) What is your time worth?
Saving money is a good thing until its pursuit starts costing you. Something to think about. Good luck with your search - let us know what you end up with 👍
WWheeler
Middleofnowhere USA
I live in rural small town USA and have several local choices of hydraulic suppliers to choose from who have every size and type (viton,nitrile,epdm,neoprene,silicone,etc) of O-Ring I've ever needed in however large or small a quantity I want. I drop in and spend a dollar or two and walk out with a small bag full of just what I need. Most of the time I don't know what type / size I need. I take them what's left of the one that failed me and they fix me up.
redwrench60
East Tennessee
You might want to re-read your post. It comes off pretty condescending when people are just trying to help.
That said, any good sized hydraulic supply store will have the O-rings you need. I’ve even had good luck at Ace hardware.
D
dkmc
You might want to re-read the condescending post I was replying to. Not directed toward those actually offering useful suggestions.
It's a whole $8 that I spent. It's not like it's an $1000 welder. Live and learn. You've never bought anything to save some money and it didn't work out? I don't have any problem chucking the HF assortment in the trash and moving on with another better quality set. I was looking for something local to fix a problem quickly. I've been a Mcmaster customer since the mid 1980's. They even send me the big yellow catalogs. Now that I've mentioned HF welders, maybe that'll start a whole different flame war. Thanks for the quality/time/efficiency lecture.
Jlarson
Find a local hydraulic seal supplier. We get out assortments from ours, along with any other oring we need. Hose places usually have assortments too.
BlakeTheCarGuy
Roanoke Virginia
I was going to suggest HF but I see I’m in the minority of having good luck with them. I have never had one fail. When we need o-rings at work they are our go to cheap and easy to have at the shop. So I’ll second McMaster-Carr as a supplier. They have really good products their o-rings are too I used them too before I started buying the big packs. Also had good luck with ones from Ace Hardware.
Zewnten
Parker or Caterpillar usually have good ones. I don't bother with the generic kits as they're usually wrong.
B_Bimmer
Eastern Iowa
I want generic kits to work very badly, I have purchased many and use many o rings. Despite this I don't think I've used the ones in the kits more than two or three times. It appears to be their purpose to include only the most useless sizes in them. Sad, and costs me time waiting for simple parts, but it's just the way it is.
phastbus
I have several generic assortments and it seems like they never work. I keep a bucket of used rubber grommets and orings, I have better luck pulling something from that.
I know this is an old thread, but I just really identified with that post from B_bimmer. I found the thread when googling where to find quality oring assortments. (Goes to show how important it is to follow up to forum posts for the next guy)
Mgdoug3
KY
I buy my o-rings from Hercules Sealing Products. Usually I have to buy them in bulk but they're high quality and have any kind I'll ever need.
rust in the eye
Chicagoland
My uses are almost exclusively automotive.
The HF sets contain very few useful sizes for my work. I bought both metric and imperial sets years ago and both boxes remain nearly full.
The few I have used worked fine.
A good assortment for automotive would be welcome so I'm staying tuned here.
Wiz02
Southeastern PA
I have a faucet that has a leaking o-ring connection between the pull out hose and the faucet handle. I tried both imperial and metric o-rings from the kits that were close in size, but the leak remained. Diameters looked like they should have worked, but they were too thin, similar issue as the OP.
Time to call the manufacturer for the lifetime warranty.
APEowner
Sunny, New Mexico
I've bought thousands of O-Rings from McMaster-Carr. A few years ago I bought this set: 1110 piece O-Ring Assortment but prior to that I just bought a pack of whatever size I needed. 100 -006 Buna-N O-Rings are $4.25.
Steve_P
I've bought individual packs of o-rings from McMaster-Carr many time. IIRC they were all USA and even had an expiration date on the package. And they were dimensionality correct, unlike my HF assortment.
