o-ring installation tool needed
aveguy
Are there any o-ring installation tools or tricks/tips for installation? Recently I had to install multiple o-rings over the length of some hydraulic valve stems which have recessed grooves along their length. Some of the o-rings are small and hard to handle. Difficult to get started over the shaft and also difficult to prevent them from dropping into the wrong slot along the the way to final desitination. Stretching is also a concern. I have seen some cone tools but just not sure how well they work. Any experience or recommendations welcomed.
A
aveguy
Thanks Hiball, I looked at the tool you linked, it's interesting but it looks like it is designed for inserting seals into the ID of tubes. I am looking for a tool to push over the OD of shafts. Any other suggestions.
Hiball
Missery
Definitely for working internally.. I mainly use them for installing rod cups on pallet jacks. Maybe a picture showing what your trying to do? Can you simply use a long straight pick to slide them into the apropriate groove?
mech-tech
For me, a long skinny flat blade screwdriver and a pic gets it done for me, sometimes you need to custom bend an old screwdriver or welding rod...and grease
gordyy
North Dakota
I worked in the beverage industry as a tech for years we had some really kewl little cupped tools made for installing them was a kit had tools like hiball's link showed some pics and some of these little cupped end tools also thin wall vinyl tubing if you can find some the right size works to keep them out of the wrong grooves (even painters tape in a pinch)
Silicon grease or spray helps make the rings slide on. Of course that make them slippery to the touch.
Related, but if you ever have to use those heavy rubber rings to hang a new exhaust system, spray the rubber with silicone.
Also Fernco sleeves slide right on the silicon spray.
Jbullfrog
Avoca, Iowa
I have a few castrators that I use to install o-rings on shafts. They look like pliers with 4 posts that spread away from each other as you squeaze the handles.
Monkey Milk
Hawaii
I think you looking for something like this. You can make your own out of brass or aluminum round stock, taper one end with a grinder and drill out the other end.
A
aveguy
Ok the pic above is a simple example of the shaft. This one only has two steps and rings. But others I have run into have as many as 4. Obviously it's not impossible to install orings on such a shaft because I have been doing it using small push stick etc. But would be easier if there was some sort of tool. Like gordyy suggested... maybe thin wall tubing?
A
aveguy
Yes those look like they would do what I need. Is oring installation the intended use for what you posted? Why can't I just buy those and be done with it? Do you have a source(PN) and are those the only two sizes?
Monkey Milk
Hawaii
aveguy, Have you looked at my pic this is what you need. Put the o-ring on tapered end, push on so it's on the larger side, then the drilled out end slides over the first step, **** up against the second step, then you just push the o-ring over. They sell these for $30 for two different sizes, but you can make your own out of round stock.
A
aveguy
Ya that sounds like it would work. But all I can find are castrators used for vet and animals. Is that what your using? Cause the ones I see only have 2 legs. Do you have a link?
Monkey Milk
Hawaii
Sorry your post beat mine, I got them from a dental supply comp. I think there to small for what you need, that's why I suggested you make them.
EDGAR
The ideal way to do it was to leave the old o-rings in place and starting by removing the farther away o-ring first so it could be slid over the old o-rings and not get it stuck in some other o-ring groove. This is in case you needed to save the used o-ring as reference to get a new one. If you already have the new o-rings it would be easier to cut them to remove them. Then, you could slide a new o-ring over the shaft, or stem, and over the old o-rings and this new o-ring would not fall in the incorrect o-ring grooves. Then you would do the second farther away o-ring and so on.
If you already removed all the o-rings either consider reinstalling the old ones so you can slide the new ones over them. Otherwise, clean the shaft with solvent to remove any oil and cover the grooves with masking tape or any suitable tape and try to slide the o-rings over the tape. Also, shrink tubing of suitable size can be put over the empty grooves and heated so it covers these grooves tight and remove them when installing the next o-ring. The tubing may sink into the groove a little but still you should be able to push the o-ring over the groove.
Or, start by installing the new o-rings by installing first the one closer to the beginning of the shaft and slide aditional (and further away) o-rings over the new o-rings. Anyway, you should use oil or grease to slide the o-rings. O-rings stretch enough that they can be slid over the new o-rings.
To install the o-rings over the beginning (or end) of the shaft, you should use an o-ring pick with the hook shape. Hold the o-ring over the shaft end with a finger and with the pick stretch the o-ring over the shaft a little until you get it completely over the shaft.
kd4gij
St. Petersburg, Fl
I put o-ring's on parts like that all the time with a hooked pick. Quick and simple:)
tomshep
What about putting tape on the section you don't want the oring dropping into? Then take a section of tape off to expose the next groove.
Tom
Hiball
Missery
+1 I thought the OP was referencing some elaborate setup, just use the pick stem to slide it towards the desired groove.
plewlandsbob
Elgin , Scotland
A simple trick, I often use is get a plastic soda bottle. Cut off the top and bottom. Keep the centre section and cut it vertically, so you have a flat piece of plastic. Wrap around the shaft you are working on and put a wrap of insulating tape around to hold it together. Just wrap a little tighter at one end ,to form a cone ,to make starting o-rings easier. You can also use the same technique, for oil seals.
For small shafts , you can cut the plastic down, to avoid having several wraps.
dieselgarage
Your always better to stretch it and work in in place than to roll it. Rolling it can leave a twist in the o-ring that will lead to premature failure.
ricleh
Sacramento, CA
I use this type tool
ChevyEFI
Phoenix, AZ
I can't think of a source, but a collet with extra grooves for wider range of expansion might work nicely.
A
aveguy
