I agree with garfunkle. Mobile application in Ohio could/will be exposed to -15 degrees F and there for viton shouldn't be used.
The large diesel engines that I was part of building a Caterpillar went to the most remote parts of the world including antartica and the hotest deserts. Hospital and Navy ships backup power, tugs, fracking and fire pumps. Nuclear power backup pumps. All applications where failure was unconsciable.
If they could trade their first born to guarantee no leaks they would. Insane the hours of engineering of parts, processes, and training to ensure leak free joints. They didn't care if things cost a few dollars more to prevent leaks, they used the best for the application. And 95 percent was nbr. Only a few viton orings were on non water cooled turbo oil lines.
Also viton on face seals will erode more than nitrile. May not matter to most bt for a product that has 25000 hour rebuild life and then was remanufactured it mattered. You could easily see/feel the erosion on the cast iron faces when some well intentioned mechanic used a viton oring (because the must be better right!)
