Obvious tool hacks that you never thought of
garfunkle24
Saskatoon, Canada
1/4", 3/8" and 1/2" key stock drilled on both ends for a small hair or cotter pin. A good way to store your crowsfeet in a very compact way. Couldn't find a pic easily.
eg I can store my 3/8" 10 - 19mm set on a 3 or 4 inch piece of key stock and they travel well.
Edit: Stole this pic from the Mac site so they obviously thought of it too :)
southalabama
Brewton AL
I'm real happy with these from snap-on, they slipped inside each other and hold firmly and they're under 20 bucksScreenshot_20250417_213627_Google.jpg
My five year old is still learning to read. She’s looking over my shoulder and wanted to know if we could cook with this. She thought it make a good spoon to stir 😂. She will learn soon enough spoons are cheaper than snap on.
bonneyman
Desert SW
Ratcheting adaptors. Homemade or store bought. These silly little things can be used with old or new ratcheting box wrenches (straight or offset), even old female drive ratchets, to use sockets. I keep accumulating different styles of them and they are so handy. I found a set of them with built-in QR which is really nice.
I keep a Gearwrench or long DBE ratcheting wrench handy in all my tool boxes with an appropriate adaptor, and can switch between box or socket as the job requires. I keep a small supply of O-rings handy to act as spacers when switching between wrench styles.
mikey03
I got a small plastic cap stuck in a bathroom sink drain last night. Tried to scoop it out with a small pick, pick got stuck too, whole handle.
i pulled the trap and got it all out and I noticed a lot of sludge on the pipe walls.
i took some wadded up paper towels and a 12” 3/8 socket extension and tapped it through with a small deadblow like it was a cleaning rod for a rifle. Did it a few times.
thought it was a creative use for a 12” socket extension
niget2002
Josephine, TX
I told my son to go hose one out with a water hose one time. Poor kid didn't think about the fact it was curved. He sprayed the water in one side and soaked himself with nasty water out the other.
Nick Rivers
USA
I keep a Gearwrench or long DBE ratcheting wrench handy in all my tool boxes with an appropriate adaptor, and can switch between box or socket as the job requires. I keep a small supplu of O-rings handy to take up any slack when switching between wrench styles.
Zewnten
Wrenches in wire hose protector or springs. Crowfoot on key stock. Small pipe for L wrench cheater pipe. PVC pipe power tool holders.
NUTTSGT
Northern Central Ohio
3/4” or better 1” pex cut offs ideally curved slipped over the handles on 5 gallon buckets.
Tip was posted here years ago and it was truly one of those wtf?!? why did I not think about that myself moments for me.
Big thanks again to whomever posted that.
I believe I had did a thread on that. I generally use 3/4" PVC or 1/2" copper. Believe it or not, the copper actually feels good on the hand.
acer66
Western North Carolina
Good to know, I deal more with pex than copper and have a coil of 1” pex that has the perfect bow in it for my hands.
Thanks again for sharing NUTTSGT.
CoogarXR
One of the tricks my shop teacher taught way back in high school was:
If you lose your drill chuck key, you can use two screwdrivers. Stick a philips in the chuck key hole, and use it as a pivot for a flat blade screwdriver that you stick in the chuck teeth. Like this:
I've had to use this trick way more times than I should have, lol.
Beerhippie
Far NE Oregon
When you lose your drill chuck key, you can use two screwdrivers. Stick a philips in the chuck key hole, and use it as a pivot for a flat blade screwdriver that you stick in the chuck teeth. Like this:
FIFY.
I grew up thinking this was the right way to tighten or loosen a chuck. IIRC, none of my father's drills had a key--for which he was more than happy to blame myself and brother.
NUTTSGT
The other option, my hack is to put an appropriate sized magnet on the head of the drill press. Just stick the chuck key to it.
I can get a picture.
Sweetcorn
North Central Ohio
That's one of my go to things I do to anything that holds a chuck.
I also drill a hole and put a magnet in the handle of a chip brush for each of my machines. Never gets lost.
Jaywalk3r
PNW, USA
Since ratchet strength has generally increased with tooth count, making breaker bars less necessary, this is probably outdated, and most members probably already know it, but …
Rotating a six point socket 90 degrees on a square drive anvil results in an effective 30 degree rotation of the socket, enabling its use in tighter spots.
KnurledNut
n/a
I recently used two painters tools to remove a sharkbite that was up against a fitting. Put the two curved roller cleaner sides towards each other to create an almond shaped oval. Thin enough to wedge in between the fitting and release ring.
Debcrow
New Mexico
-This is an old one but I'll throw it out there for the new members of the Knuckle Busters Club
Somebody called this a handshake wrench.
Brought back memories that I was not going to mention here, but since someone named It guess I will share it.
My older brother that originally showed me this called it "Wrench 69"
larry4406
Northern Virginia
Put your key on a chain, you'll never lose it or pinch your fingers again. Make up a wrench cheater and you won't break another wrench.
Wrench cheater. Clever.
How could you make this work for multiple wrench sizes? Looks like the block is sized to the specific wrench.
