lonestarky
Hi Everyone, I searched a few times and couldn't find the answer I was looking for. I hoped if I asked, the electrical geniuses here would be able to help me out.
My wife and I moved to Chicago IL a while ago, and built a new house. You'll know why the location is critical in a minute.
We moved from KY, land of 3 wire romex. Now I have two wires in my j boxes, and what I would assume is grounded conduit?
The occupancy sensor switch needs a ground to run the low current electronics that control the switch itself.
The 1st switchbox I tried (out master closet) has a yellow and blue wire, and thats it.
I assume I connect the two black wires on the OCC to the yellow and blue, in no particular order, and then run a ground screw to the back of the j box for the ground wires (there is no screw there now, but there is a threaded hole).
Is this right? I suppose I should test hot to the box with a multimeter to confirm the box is in fact the ground, correct?
