Octagon window and siding
AllDodge
KY
Getting the materials together to vinyl side our rental house. The house has 2 octagon non-opening windows. They are wood and the molding extends out more the the J-channel.
I want to cover all the wood I can to seal it up, and I have a aluminum brake. I can bend 8 pieces on metal, and try to overlap each and use sealer of some sort. This will take some work and I'm not real sure I will like the outcome.
Thought about removing all of the exterior wood molding and then place aluminum over and around the window, then install J-channel around. Could also install Plastic trim around the window after removing the wood trim, seal and go with J around it.
Most octagon windows have a square hole which has had 2x installed to make it 6 sided. Could remove and replace the windows with a square one, but really don't want to go that route.
Anyone have any opinions?
Other forums that deal with this kind of stuff?
anythingyoucanimagine
New England
Other forums: places like fine home building.
They sell octagon windows with integrated j channel. They actually aren't as crazy expensive as I thought they were going to be... and in hindsight, it was worth every penny.
I'd look for the cheapest octagon window with integrated J and make the hole fit the window. It's SO much easier with a nail fin and integrated J....
A
AllDodge
KY
Thanks, will see if I can find what you mentioned.
Don't really want to remove the window if I can keep from it, If I do remove the window, thing I'll just change it to square.
The blur pic on the left is the house, and the one on the right is a stock pic which someone used silicone which I don't like
spudley
Northeast Wisconsin
Get creative with the break and trim over any wood, install vinyl J around that and you're good. Make your J tight as there won't be much expansion/contraction in less than one foot pieces.
A
AllDodge
KY
Can do that, but would really like to change the brick to something shorter. It sticks out past the J
spudley
Northeast Wisconsin
They do make a wider J which may work, or remove the brickmold and replace with a thinner board.
On my garage and house, I trimmed around windows (including one octagonal),doors and corners with 1x4 cedar and placed J tight to the cedar.
I'm not a big fan of brickmold trim.
A
AllDodge
KY
Agree reducing the size or the wood around the window will reduce the amount of aluminum need to cover it. Don't know how much of a gap there is between window and framing, but will find that out if removed.
Will keep looking, thanks for all the ideas
Milton Shaw
Years ago my wife asked me to make her a pattern for stained glass. She asked for a hexagon 14 inches across. So I made her one to use as a pattern. She made a beautiful stained glass panel. Except when we go ready to put it in the door, it was an octagon instead of a hexagon. She eventually turned it into a hanging decoration and cut a piece of colored glass for the door. I have learned to count sides on anything else I do and measure for myself.
mike93lx
Richmond, VA
I would install a vinyl window way before thinking about bending all that aluminum and installing a separate j channel. Way less work
