Odd gas grill question
Rick B.
East Tampa
Being the fabrication section and folks are always working on all kinds of projects, I was wondering if any of you have spent any energy on coming up with a better retrofit for a gas grill spark starter system. I'm really tired of replacing the standard ones every 6 months to a year. Has anybody expended any effort in this area???
Willie Makeit
drill a hole in the grill body and use one of these.
mike93lx
Richmond, VA
The electronic ignitor on my kenmore has been working for something like 12 years. Just replace the battery every 1-2 years
texasranger
Maryland
+1 for Kenmore. The heat shield has rusted in half but the sparker is still going after 3 years. Can't remember changing the battery, so must be original.
mike93lx
Richmond, VA
Same here... The accumulator is gone on the left side, so i light it but runming the gas for ~10 seconds and then lighting up. The woosh of flame is always neat to hear
Marctrees
TX/LA border - Toledo Bend
The typical battery less pushbutton ones last a long time, OTHER than the problems coming from degrading connections.
Or false ground tracks on the insulator.
Greasy dirt, etc.
The spark will jump the highest resistance part of the ckt.
If there is an "easier" lower resistance path, it will take that.
Keep all connections clean, should be good long time.
I don't understand the purpose of the battery ones.
Totally no need, just another battery to worry about being ded.
Anyway, I use the cheap long lighters also.
Gas grills already have holes in bottom not only for airflow intake, but mostly to drain off propane accumulation.
Poke the long lighter through one of those. Marc
American Locomotive
Rhode Island
It's funny. I've never had any issues at all with the old snap-action piezo igniters. While on the other hand, every grill I've had with a battery powered igniter has failed.
