Today we had a power outage so I pulled out my Generac 5500 watt gen set. Claims like 6800 "starting" watts or around that. Fairly new unit, maybe 6-7 years old, if that.
Your friend has shared a link to a Home Depot product they think you would be interested in seeing:
Used at my old place a couple years ago during a several day outage, worked ok.
All seemed ok till I realized the well piping was sort of humming and then noticed it wouldn't build water pressure past about 55psi. Normally it's on at about 45-50 and off around 65-70.
I checked voltage and I was sitting at about 245v.
It was loading down the generator like I'd expect.
Tested the dryer and it seemed to work, but didn't sound right. Hmm.
The boiler then came on, it's 120v, maybe 300 watts. It came on but the inducer fan sounded odd and something was causing the boiler to vibrate to the point I thought it was an airplane outside at first.
I started wondering if it was something strange with my wiring so I ran a cord out and just plugged in the boiler to the 120v outlet on the generator and no difference.
Edit... just remembered the boiler is actually on 2 outlets. The one I plugged direct to the gen set I think is only the boiler, no circulator pumps.
Everything else seemed to work ok. Washing machine had been in when the power went out, it finished the load. Lights worked fine, fridge. Battery chargers, etc.
I wanted to verify the frequency but the kill a watt meter I had **** the bed a while back. I ordered a replacement on Black's Friday but it hasn't arrived yet.
Any ideas?
Generac 5500-Watt Recoil Start Gas-Powered Portable Generator 5939 - The Home Depot
Get reliable power when and where you need using Gasoline Powered Portable Generator from Generac. Features low-tone mufflers for quieter operation.
www.homedepot.com
Any ideas?
