I plan on purchasing the 60gal. Kobalt compressor from Lowes tonight and I am trying to get all of my ducks-in-a-row for the wiring portion. I have seen many people post that they(Kobalt/Lowes) recommend the compressor to be hard-wired so that's what I'm going to do. I could put a plug in later if I want to, plus my breaker is 15' from the compressor so I should be fine as per code(please correct me if I'm wrong).
My question is how do people suggest routing the wire for a hard-wired set-up? I would like to keep it as clean as possible and run the wires through the wall, but how do you run the wire from the wall to the compressor? Does it just come out of a hole in the wall(with maybe a decorative faceplate)? Is there some type of requirement for conduit for the wire...or is the wire just exposed romex with a clamp going into the compressor? The idea of running a wire straight out of the wall just sounds ghetto.
