odd request: tan/brown ball bearing grease identifiable? (Pics inside)
Sdot
Loading
Hey guys
Weird one here.. but isn't that what makes GJ so great? Yep! :D
Need help identifying this grease. Its used in automotive seat slider applications. Definitely not spray on - looks like out of a gun, or brushed on.
Common in European vehicles. Any guesses? or close substitute?
Read about Wurth Tru Glide - don't think this is it.
ddawg16
S. California
I am.
I have no clue....I've never seen that type. Sure it's not a spill from someone lunch?
Normally, they use lithium grease in those slides.
CoreyB
Central, CT
Castrol's Olista longtime grease is brown in color and frequently found on euro cars. It is probably very similar to what you're looking at there.
Sdot
Loading
I am.
I know that's how it appears, although...
Nope, its a brand new part.
Thank you! going to look into it
Weathered heavy white lithium grease is my guess.
Brand new part
Hi could be Castrol LM grease ( low melting ) at a guest
Will look into this.
six-point socket II
Hi!
AFAIK, BMW, for example, uses/recommends: Klüber Isoflex Topas NB 5051
It's beige as pictured, has a fairly long lifetime/ doesn't oxidize quickly/ offers good protection against corrosion and wear/ sticks very well to smooth surfaces (probably all wanted on seat sliders) additionally has a pretty large temperature range (-60 °C - +130 °C / -76 °F - +266 °F) Dripping point: >= +170 °C
Current price in Germany: 400g cartridge = 129,** Euro incl. VAT.
Kind regards,
Oliver
BiggityBen
2-4-C grease looks like that and can be found in West Marine and some auto parts stores
bwringer
Indianapolis
Interesting question. You do want the correct stuff; all the various wheel bearing and other "mechanical" greases I know of would eventually separate and stain the interior. This stuff has to stay in place through years of hot and cold cycles, so it's definitely something special.
Sdot
Loading
^ Exactly this. And why im trying to go the distance finding the right stuff, even though sounds insignificant.
bwringer
Indianapolis
After poking around on McMaster-Carr, something like "Carriage and Guide Rail" grease seems about right:
It's brown and very thick, about like peanut butter.
toplessHO
central florida
hi tack red n tacky ,altho bright red has some pretty good tackiness
I would recommend anti seize but I just got some on fingers typing the words
Sdot
Loading
That stuff separates like crazy. My grease gun is wearing a diaper.
Yeah the big thing for this specific grease - is it needs to not run off the seat slides while baking in the car in 100+ degree weather.
Good recommendation on the mcmastercarr link. I did pick up some bicycle grease with "TEFLON" and by the smell of it - it seems we are getting warmer. The color is not correct, but I think the Teflon is a good clue?
KnurledNut
n/a
I dont know what it is.
It has probably discolored over time anyways.
Id use SilGlyde as @Wrapitinbacon mentioned.
Or if i wanted to get fancy, i might use ShinEtsu silicone.
Bacon!
Looks a bit like the sodium grease everyone used to use for wheel bearings a half century ago.
However if there's a bit of rust in it for the orangish tint, or they added dye to get there, then it could be the low grade lithium grease you find cheapest at any auto parts store and if not very old grease, that seems most likely. Example: https://www.autozone.com/greases-an...e/p/stp-hi-temp-grease-tube-14-1oz/561738_0_0
Whatever it is, it's not particularly important to use the same thing again, just clean all the old off. I'd choose a tacky lithium complex NLGI 2, or if 100% sure there's no chance of getting any drop off onto carpets or clothing, then also with moly. On the other hand if your winters are extremely cold, then one not so tacky, even drop to lower viscosity NLGI 1 (and less of it, to avoid making a runoff mess when it isn't so cold), or if there are plastics seeing friction too, a silicone paste instead.
Bacon!
This doesn't matter nearly as much when putting a thin coating on something, opposed to a larger volume container where gravity (assisted by heat) allows the thickener to settle to a higher concentration and the oil to pool.
