Odd squirrel question
lowcountrygamecock
So my trailer lights quit working recently and I finally got around to working on it today. I figured out I didn't have any voltage at the plug at the back of my truck so I popped the hood to check the the fuses and found a squirrel looking at me. I didn't want to run him out from under the hood in my garage so I backed out and tried to flush him out in the yard. But he moved and now he's hiding in the very back and won't come out. Anybody have any suggestions?
L
lowcountrygamecock
Ha I like the test drive. I want to get my lights fixed but I'm not about to stick my hand in there to pull off the fuse box cover witha scared squirrel hiding right behind it. Hopefully he'll be gone tomorrow.
fury9
Mchenry, IlLaHnoYs
HE'S FREAKED OUT! Just drive the truck tomorrow like you normally do, He knows it's time to get out when you start it up, He must be a bachelor
Old Moparz
Newburgh, NY 12550
Get a very bright light & a pair of binoculars, then use both to see if it's a male or female. Once you have that issue solved you can use a trap to catch another squirrel of the opposite ***. Bring that one back & set it down in the trap near the other one's hiding spot to lure it out. It should work unless you're unlucky enough to have a gay squirrel. If this is the case you'll need to start over with catching another squirrel. Whatever you do don't let the squirrel you caught out or it will run to where the other one is & your problem will be multiplied. If that happens & they're gay squirrels you'll be known to your neighbors as the "guy with the gay squirrels" on the block.
fury9
Mchenry, IlLaHnoYs
Yep^ what he said, or just kill it
AbitNutz
Man just do what my old boss did. Close all the doors and leave the truck running for a few hours. Heck it killed him and he was a jackass so it should work on a squirrel.
pmiranda
Austin, TX
Or vinegar... critters don't like that either.
Or borrow the snake from the feller that got one in his garage :)
G_P
Central CT
Got a pellet gun? Shoot it and be done. Don't use a .22 as you will end up overpenetrating and hitting the vehicle.
Sent from my C5120 using Tapatalk 2
