Oddball Snap-on Sockets
mtkst19
blitzburgh pa
S9549, deep, two pointing things on end of socket, $8---
i think that may be for removing headlight switches. older style where you remove the knob then have to take out the bezel that has 2 slots.
i would liek the following crowsfeet-
1 1/16 SC034, width is ground down, $8
and
22 mm, $11
pm forthcoming
Red Green
South Central Michigan
½ dr, WA12A, $22
½ dr, WA13, $22
Do you know if either of these are the proper size for 78-87 Gm Mid size cars? Like Monte, Cutlass, Regal type cars.
1stwarrior95
A135 & A136, $4 each
B2190, 5-point socket, $9 each
A138, A137, Shock Absorber $8 each
I'll take these. Pm on the way.
mtkst19
blitzburgh pa
3rd picture 2nd row 3 rd over from left what is it
sfs201 is the part number for a normal 5/8ths deep-well 3/8 drive socket. As you can see someone cut a slot in it. likely they cut the slot for a specific job. think of an o2 sensor socket w/ a slot cut in it. however, o2 sensors are 7/8ths or 22mm.
so my best guess is they cut a slot in it to remove a pigtailed sensor, or maybe used it in conjunction w/ a valve spring compressor. the slot allows them to grab the keepers w/ a magnet while the spring is compressed. last thing i can think of is maybe to remove a diesel injector--but most diesel injectors i ever seen are bigger than 5/8ths.
