Of Roller Coaster Connectors and Split Systems.
A_Pmech
IL
I've read a number of threads on mini-split systems here, unlike most other forums. I'm posting this thread to explain the logic behind my choice to purchase and install a mini-split system with three zones in my house.
Monday evening, I got my system up and running. It's been a long, multi-year road, which I haven't finished yet. I did 100% of the installation work, except for the sizing calculations which my dealer helped me with. Along the way, I've become a believer in these types of systems.
As you'll see, the story is rather complicated as several factors came into play which more or less forced me to choose this type of air conditioner. I'm glad they happened, otherwise I wouldn't have purchased one.
The Roof
Several years ago, I began the design work on my house, a joint effort with my father, which we've been building a few dollars at a time. I won't bore you with all of that, except for one detail: Rafter to Joist attachment. I wanted a 4-in-12 roof pitch, which I felt was perfect for the look I was trying to achieve. However, in my experience, traditional joist-and-rafter construction leaves something to be desired. Over time, the nailed connection between the joist and rafter slips, while the shear walls on either end hold up the ends of the ridge board, causing the roof to sag, or "swayback" in the middle. I didn't want that to occur with this house.
In addition, it takes at least three men to assemble a joist-and-rafter roof, yet there were only two of us. I considered the truss route, like many do, but then I'd lose all the attic storage space on a low-pitch roof. Further, the local fire departments will not place men on a trussed roof, as the "mending plates" used to construct the roof are driven out of the wood under high temperatures, causing the trusses to collapse.
"Roller Coaster" Connectors
After several days of searching, I came upon the solution: Teco Split Ring Connectors. They are now sold by Cleveland Steel. According to the Cleveland Steel engineering representative I contacted to obtain engineering data, their original use was for building wooden roller coasters!
Ring Connectors are essentially a 3" diameter rolled ring of 3/16" 1018 steel, split though on one end and beveled both sides. They are installed into an annular groove, cut into the mating pieces of lumber by a special tool which runs in a pre-drilled 1/2" pilot hole. When assembling, the ring is seated into the groove on one piece of lumber. Then, the two pieces are brought together and the ring is made to seat into the mating groove in the second piece using a mallet. Finally, a bolt though the center of the assembly in the tool pilot hole keeps both halves sucked together. They are used in roller coasters and commercial wooden construction because the are reliable, do not slip, are highly efficient at transferring the forces, vibration resistant, and the joints can be inspected.
By building my roof using trimmed 28' 2x8 joists, and 16' rafters, I was able to transfer the tension load efficiently between the connectors on either end of the roof. In addition, each unit could be assembled on top of the wall plates, then turned vertical, opened up, and closed over the ridgeboard - a two person job.
Here's a photo of a left-over ring connector and the tool used to create the annular groove:
Painted into a Corner
However, this type of construction presented a challenge which I hadn't initially considered: Where to mount the air conditioner and ducting? It had to go in the roof, as part of my machine shop is in the space below. I need every bit of overhead I have.
When it came time to consider buying the air conditioner, I was left rather stumped. My local HVAC outfit wanted $8,000 to install a standard central-air system. However, big ducts would take up most of the attic space, which was not in the plan. I could spring for $12,000+- and they would install a "high velocity" system using small, flexible ducts. But they wouldn't guarantee that it would work for my application. I would still lose a lot of attic space.
My Introduction to Mini-Split Systems.
It was then that I got to thinking: Commercial buildings use split systems, where the evaporator has a self-contained fan and several evaporators are hooked up to one compressor to provide multiple zones. Instead of bulky, inefficient, noisy ductwork, they have a couple 1/2" diameter (or smaller) refrigerant lines and an electrical umbilical. Why don't they make something for residential applications that works along the same lines?
After some internet searching, I realized they DO make such a unit. Shortly after, I purchased a Sanyo CM 2472 with three evaporator units last fall. It's marketed as just over a two-ton unit at 25,400 BTU.
A
A_Pmech
IL
Installation
Installation was straightforward. I had to make a roof bracket to mount the unit on my sloped roof. Running the copper refrigerant lines, insulating them, and pulling 14-3 NM cable took a couple days. The unit weighs about 250 lbs. and my roof is 23' up. I WAS NOT going to push a unit that weighs double what I do up a ladder!
I ended up making a 14' boom pole for my forklift to lift it into position on the bracket. A modern engineering marvel, tested to a safety factor of 3 with concrete blocks and 150lb cast steel tractor weights. The only thing I liked less than pushing a 200lb unit up a ladder was dropping a $1,800 unit from a height of 25'. At least with the ladder, my body would cushion it's fall. :bounce:
The only brain teaser I really had during installation was figuring out how to get the line sets though the roof. Naturally, I was afraid of leaks. I ended up running a 4" PVC DVW pipe through the roof using a standard roof penetration, next to the 2" EMT for the wiring which also used a standard plumbing penetration. I capped the 4" pipe with a 4" cap then used a 6" to 4" rubber DVW coupler to form a rubber "hat". A slit in the side of the vertical pipe admits the line sets into the pipe and through the roof. Each line has been bent into a drip loop to prevent water running down the line and into the house.
One of the line sets stubbed out in the framing:
After roughing things in last year, I didn't touch the system again until Sunday. I was too busy getting in heating and mudding drywall over the winter to worry about mounting the indoor units.
On Sunday, I mounted the indoor units. I was surprised how quickly they mount up. Simply install the wall bracket, cut the tubes where they're marked on the wall bracket, flare, lubricate the flares, and connect the unit. The Japanese thought of everything on this thing, no detail is overlooked! To remove the condensate, I ran tubes down though the walls and into the shop below, where a 1" PVC drain line runs outside the building.
Condensate collector:
Monday, I took a trip down to the local HVAC supply and bought a new tool, a Yellow Jacket 6CFM Super Evac vacuum pump, to pump out the line sets. Once home, I got to work. After pumping out each line set individually to the necessary micron level, close off the manifold and open the high side service valve for ten seconds to charge the lines. Then, open the low-side service valve all the way. Finally, open the high side valve again, this time all the way. Remove your manifold and you're done! The unit comes pre-charged for up to 150' of line!
A new tool!
Pulling down the lines:
Back inside, I was anxious to test the system, as I abhor loud air conditioners and air handlers. I wanted to know just how quiet this thing really is.
One of three installed wall unit:
Wall unit remote control:
Impressions
The cooling ability of the unit is IMPRESSIVE.
I can't hear the compressor unit sitting directly beneath it in the attic! I can just hear a faint “whirring” noise If I’m standing on the ground, looking up at it on the roof. I live in a rural area. Excepting the crickets, it gets very quiet out here in the evenings.
The indoor units are whisper-quiet. Much quieter than any central air system I've ever heard. No more duct rattles, whistling, or screaming blowers.
The controls are incredibly sophisticated. The compressor is a variable-speed unit, controlled by a VFD. Thus, if the cooling load is low, the compressor runs at a lower speed, instead of full-blast like a traditional central air unit. So, it's possible to oversize the mechanical without worrying about short-cycling an oversized air handler. Short-cycling cools the air, but leaves it clammy, as it doesn't remove the humidity. Plus, having a remote control for your air conditioner is just snazzy. It's 2am and you're cold in bed? Pick up the remote!
Conclusion
I have to say, I was a little worried about the unit's performance when I first bought it. However, after installing one and using it, I have to say Sanyo got it right. I will NEVER buy a central air unit, EVER!
With the air conditioning on inside, I can now concentrate on tile and trim. I have a few tons of rough Walnut awaiting my attention. Once the humidity has stabilized in the house for several weeks (humidity is the bane of a Midwest woodworker), I can begin working this:
gyroplane
I will second the Mini-Split. We installed a Mitsubishi "Mr. Slim" (looks nearly identical to the Sanyo), mostly out of necessity, because the ductwork would have been complicated to get the existing furnace ducting to the new office space we built over the top of the garage. Living in Seattle, air conditioners are not common, and on our shaded lot we would not have otherwise installed A/C. As it is only just starting to warm up here in the NW though, we are already SO GLAD we were forced into the decision. The unit is super quite, and works VERY well. Installed it ourselves, and charged/tested it with the help of a HF A/C Manifold gauge set. We are now rethinking all of the other rooms we should have installed them in...
-Sky
