Off topic but need some electrical help.
daddycreswell
Middle Tennessee
I am in the process of building a heating box to warm polycarbonate. I am using 4 heating elements from a toaster oven. I wired it all up tonight in series and they worked but didn't get hot enough. So I tried wired parallel and it kicked the breaker as soon as I plugged it in. So is wiring them in series/parallel the way to go. It's 110 volts. Any help would be great, thanks.
inphx
Phoenix/Scottsdale AZ
If they are rated 120v - when you wire four in series each is getting 30 volts.... so it wont get hot
If you wire in parallel - each gets 120v. If each pulls 20 Amps (i dont know what each will pull) then 4 in parallel will try to pull 80 Amps.
They most likely need to be in parallel by design - you need wiring and power to feed it.
67carl
California
Can you get an old junk electric oven? Use that to "bake" the plastic. I see many on craigslist in my area for cheap.
nehog
Jaffrey, NH
The obvious right answer is to wire them the same way they were wired in the toaster oven! :lol:
Just guessing I'd say series/parallel is probably how it was done originally. If they are identical, connect two in series, and measure the current they draw with your clamp-on ammeter. Should be about 4-6 amps (about, can vary of course) so that both sets would draw about 8-12 amps total.
D
daddycreswell
Middle Tennessee
I tired parallel, then in series. I have attached pictures of what I have tried and the series/parallel I think I need to try.
are they all out of the same toaster oven? how were they wired ? could they have been 2 each in series then the 2 sets wired parallel?
Look at my crude drawing, I best I remember this is the way it was wired in the toaster. It's been a couple of months since I took it apart but just now getting to working on it.
D
daddycreswell
Middle Tennessee
I ended up wiring them series/parallel and it worked like a charm. Only problem now is I need to add 4 more elements in order to get it hot enough. I'm going to wire the. To a separate cord.
Sent from my dumb apple products my work makes me use.
