who has a 45 degree offset breaker?
That looks like a regular breaker bar .. am I wrong?
The square drive is "turned" 45 degrees, to allow a slightly different (well, 45 degree!) angle for the socket to engage.![]()
Oh ... ok; thanks Moose
Don't own one of those 45 degree offset breaker bar then ..
Personally, i've never needed one. Well, yet.help me. 12 pt socket = 12 positions, breaker 4 sides= 4 positions, 45 degree breaker 4 more, 12 x 4 x 4 = 192. with 192 positions who needs an 80 point snap on. what happens with a 12 pt fastener? twice as many points so 384 positions. i may be off with my math.
... Torque multiplication
to multipy torque there would have to be a planetary gear set wouldn't there?The benefit is lost on me.
if you keep rotating the socket and switching between the two bars you should be able to come up with that many positions. same theory behind the angle wrenches. flip them side to side and end for end to get the different angles. 360 degrees divide 80 = 4 degrees of ratchet swing. my question then 12 pt socket with 2 dif. bars can you get 360 divide 182 =1.978- degree for bar swing?
most older breaker bars were 45* offset. i don't see the need myself.
Say Krusty, where are you getting that info on older bars? I have them from pre War, to today, (14 bars) and none are 45 offset. Which, I agree would have minimum use. I have Williams, Wizard, Craftsman, Snap-On, Challenger, ForgeMaster and others, some from the 30's, 40's 50's and 70's but none offset.
why are all the tool junkies ragging on a tool?chris..........all but one of the early snap on breaker bars i own are 45* off set...........
i guess i should have stated that "most early snap on breaker bars" sorry for the confusion
Are you sure you guys are talking about the same kind of offset? I understand that the OP means the square drive on the bar is rotated 45* from the more typical position, perpendicular to the axis of the bar.
From this post, with you saying you've encountered none of them, I'm wondering if you're thinking more of an offset (ie bend) in the bar handle itself?
user, let's get together and make a 22.5 degree bar and we will be rich. we shall be the new snap on !!!!!!!!!!!!!!!!
