When using calculator for bending offsets, do you measure from the wall to the edge of the KO circle, or to the middle of the circle?
When I bend the second bend it usually unbend the first part of the bend, not sure what is the best angle to use?
In this case, my KO is about 1.75" away from wall and I only have about 20" of vertical to work with, maybe even less if I count the LB length.. what angle is good to go with?
