se3388
I have a Reddy Heater 110BTU and when I plug it in and turn the T stat up it'll come on and work fine until it gets up to temp (where the T stat is set) maybe 15 minutes or so and cycle off. After 10 minutes or so it will come back on and run maybe 10 or 15 seconds and shut off and give off a heavy kerosene smell then shut off. I can unplug it, cycle the Tstat and plug it back in and turn the Tstat back up and it will come on and run 10 to 15 seconds with the heavy odor. If I unplug it and go back the next day it will run the first time for 15 minutes or so and then short cycle like before. I replaced the square plastic housing and have a pressure gauge installed that says it is running at 5.2 lbs. Fuel lines have been replaced and are getting fuel. Fan works good.What say you experts?
Steve.........
Steve.........
