oil absorbent pads
man00
Any of you guys use these ? If which brand seems to work the best ...if any
thanks
Just_Steve
Dutchess County, NY
I wish I knew the ones we used at my old job 2 ft x 2 ft squares one side oil absorbent the other side coolant absorbent. I had a box or two. now regrettably I have none.
bwringer
Indianapolis
Pig Mats are great, but flippin' expensive... and fluids can still get through them.
I use these cheap absorbent pads from Costco under messy jobs. A box of 100 is about $18 in the store.
They're not incredibly durable -- the plastic backing is very thin -- but they are very absorbent on the other side and will soak up a LOT of liquid nasties. And they're cheap.
Did I mention they're inexpensive?
And low cost as well.
Despite the puppy on the packaging, these are not treated with any sort of smelly stuff to attract and inspire puppies. They're just plain pads. Floofy on one side, plastic on the other, with absorbent gel stuff in the middle.
I've started using them underneath when I have to do any drilling; they do a good job of catching the drilling lube and cleaners, of course, and they catch the chips. It's quite nice to be able to just fold up the pad and throw it away with all the chips for under 20 cents.
nadogail
Coronado, CA
Pig Products seem to be the best marketed products and they do work. A former employer bought their products and in addition to the products being good their Customer Service was good too.
Sumboodie
AK
FyterTech Nonwoven. Made in USA. About $45 a bale.
Shops in Wisconsin and Anchorage.
Blueshound_GJ
I have a whole bundle of unused 24" puppy pee pads (Hefty brand I think). I use 3 or so for an oil change. Probably have 5 years worth at the rate I use them and they were very cheap. I wouldn't try to use them professionally though, not really ideal, too small.
LWB
ON, Canada
I use pee pads too. I had some left over when raising the pups and have been using them ever since.
scooby074
Nova Scotia
Pig Mats. But damn pricey. Their customer service line is hilarious and super friendly if you ever have to call too. They REALLY bought into the whole "PIG" identity and concept. :lol:
reader2580
Minneapolis, MN
Oil absorbent pads only absorb oil and other petroleum based products. Pee pads are not the same thing. A pee pad will absorb any liquid including water. I have a stack of 50 oil absorbent pads I bought for collecting oil that was on the surface of the water in some pails. I have used some to clean up an oil spill on concrete and you couldn't tell there had been any oil on the concrete within 30 minutes or so. Way better than oil dri.
I got mine from Zoro: https://www.zoro.com/spilltech-absorbent-pad-absorbs-10-gal-oil-only-50-pk-white-wpd50h/i/G4807168/ Various oil absorbent pads will absorb different amounts of oil. The more oil they absorb the more they cost.
Pig is the big brand in selling oil absorbent pads at retail, but they are not cheap, at least for retail products.
bwringer
Indianapolis
Oil absorbent pads only absorb oil and other petroleum based products. Pee pads are not the same thing. A pee pad will absorb any liquid including water....
Excellent point. There is a difference depending on exactly what you need to accomplish.
As ever, the GJ answer to "which tool/product?" is "Yes. All the above." We're very damn consistent around here...
Cheapo peepee pads are extraordinarily useful in many situations, but oil absorbing pads are well worth the eye-watering expense in other situations.
cannuck
Rural SK
Oil pads are polyester matting and in my former work we used them at every branch in North America on a daily basis (we handle oil). What I find is you can buy them in different thicknesses - based on just how much you expect to spill - but I can predict how good or bad they will be by hardness. The stiffer ones DO work, but no where near as well for both surface compliance and rate of absorption. None are "cheap" but get your money's worth by finding out what brand in your area work best. One thing we have used them for is when someone spills oil into a catch basin containing water. The pads will float on the surface and only absorb the oil. Also extremely useful for spills on a rainy day that hit puddles.
reader2580
Minneapolis, MN
Someone asks specifically about oil absorbent pads and people keep bringing up things that will soak up oil, but will also absorb any other liquid. I would assume the OP has a specific need to absorb only oil, or the OP wouldn't be asking about oil absorbent pads that can be pretty expensive.
Blueshound_GJ
Not what I assumed. OP's request was pretty generic. And he didn't specify expensive either.
Sumboodie
AK
I used oil absorbs when I had my pup. The grey ones absorbs water. White is oil only.
bwringer
Indianapolis
Does Pig Mats have some sort of a plastic lining to prevent soaked oil to leak through it?
No, the oil can soak through. They will hold a lot of oil, but eventually it will get through.
They are ~$1 each, wouldn't say that's "eye watering" expensive.
I don't know about you, Mr. Rockefeller McFancypants, but $1 each for a small patch of something I'll need to throw away counts as kinda expensive in my world.
Puppy PP pads are three or four times the size and 17 cents each, and they don't soak through unless you damage them. Of course, they're not as tough or as useful in some specific situations.
I have both on hand, and other options besides, but I think hard before grabbing a Pig Mat and setting that dollar bill on fire.
finn
The UP, God's country
I really twinged when I bought a roll of pig mats maybe ten years ago. Seems like it was almost $60 delivered.
Funny thing is, I still have probably 50-75% of that roll.eft. I use it sparingly and find that one square is often enough to address a moderate spill. I follow up with oil dry or even white indust paper towel and brake clean, and then a bucket of detergent and hot water.
That $60 seems like a bargain now.
Blueshound_GJ
Seems like it would be the same amount of work to skip the pig mat and just throw down speedy dry. What am I missing?
Sumboodie
AK
Where are you buying 6x6ft piss pads for that cheap?
NUTTSGT
Northern Central Ohio
I have a few left over from the trash at the station. Someone tossed a few after using them to spray paint a few things on. Good enough to still use them.
Cost is relative to each person and what you're using them for. They're a consumable and I will treat them as such. At $1 each and not have to clean a spill up or not getting a stain on the concrete, well worth it in my book.
Kpaige
Big Lake Minnesota
I ran into a deal on pet potty pads. Got hundreds for $20. Work really good for oil and such. Use it when cleaning parts on the bench also. So if you see a good deal on them may be worth it. And the oil does not soak through they are plastic on the bottom side.
finn
Pig mats/booms. As mentioned, they are not cheap, but they do soak up oil.
In a pinch, I've used cat litter.
Kitty litter works better than some of the commercial oil dry products in my experience.
I usually keep a small pile of lightly used oil dry / cat litter in a pile on the floor, in an inconspicuous place, for quick clean up of minor spills. (I guess that’s why a roll of pig mat lasts so long,)
Works ok unless I accidentally step in, or kick the pile. Then it’s out the door with the push broom (or at least into the dust pan).
