Junkman
What is the requirement for having a disconnect switch on the main floor when the oil burner is located in the cellar? In my home, there is a switch located high on the hallway wall that controls the oil burner in the cellar. The switch on the main floor interrupts the power to the switch on the burner case, so if it is turned off, the switch on the burner has no power. The burner itself has a switch mounted on the case to turn off for burner servicing. The main floor switch wiring was installed early in the construction, and later during construction, the stairway to the cellar was moved to the opposite end of the cellar. Is the switch required to be near the cellar stairs? Is this switch actually required by code? The burner itself has a switch mounted on the case to turn off for burner servicing.
