Hello,
Hate to lean on you guys like this, but I have a question about a diesel burning furnace, Beckett furnace heating a mobile home. There is a story that goes with this, please bear with me:
About a year ago I emptied my oil tank into smaller 45 gallon drums. I got these drums from an acquittance of mine, and inquired about some liquid I noticed in the bottom of these drums = the acquaintance promptly stated that these drums will be fine, there is only oil in the bottoms and your furnace will like a little bit of oil, good for the pump he said...
After pumping all the oil, and other unknown liquid, back into the furnace and changed the filter, I bled the line - right away I noticed that the diesel was very dark, and contained some strange colored liquid that was not mixing with the diesel. I bled the line until I thought the water/unknown liquid was gone (as I thought it was at the bottom of the tank), and the diesel appeared clear in color.
We used the furnace like this for a few months and noticed that the furnace frame was getting hotter than normal. I had some Oil burner mechanics inspect the furnace and service it - they apparently adjusted the ignighters, and install a new nozzle...We continued using the furnace as is, thinking the problems were addressed...the mechanics looked down the chimney, and said it should be okay, keep using it. The furnace continued to get hot, and while I was out of town my wife called me in a panic saying the furnace was burning overly hot, and spitting out black smoke out of the chimney. She said it was making loud noises and filling the house with smoke.
NEW DEVELOPMENT>>>
Today, I changed the nozzle again as I thought that the contaminated fuel couldn't have been good for the running issue. While the nozzle was out I noticed that the ignition points were not set up correctly and I did my best to make the necessary adjustments 1/16" in front of nozzle, 5/16" above center of nozzle, and 7/32nd's apart. Don't have feeler gauge, but got as close as I could.
Brought new diesel into equation and omitted the filter (hooked a line into a jerrycan of diesel after filter right into furnace) - crazy running problem now. Almost sounds like a car misfire - it makes popping sounds, and puffs of smoke come into the house. Next thing I was thinking about doing was changing the ignition module? I don't really know what to do?
One more thing worth mentioning, I had the entire guts out and looked into the fire box (I think) I noticed that there appeared to be almost like an insulated liner with ports, but there also seemed to be cracks in the insulation and I am wondering if this is causing the running problem?
Sorry about the novel
Thank you for any advice....
NEW DEVELOPMENT>>>
