Could use some advice:
Installed a forced hot air/Kero-Oil burner. Had been used in "double wide", draws thru fornt and hot air out bottom.
Anyway, worked great last year with plastic hose stuck in Kero can for winter needs. I would bleed and prime burner and it would work great unless it ran out of fuel, then I would bleed agan.
THis season, It won't keep primed. It needs bleeding to prime to fire, just after a few minutes normal cycle. Only change was I plumbed an old copper oil line thru the wall to put the can on other side.
I can't find any leaks or problem with copper line, Do oil burner gun motors have check valves ? What prevents gravity/siphon flow back to tank? I never had this problem with years of fooling with burners. But I never thought about it...
Advice or analysis appreciated..
Don't have apic of burner/pump yet:
