Oil change 4 hp 20 gallon craftsman compressor
Cadmandu
Va
Hi all
I have a 20 year old compressor a craftsman. I dont know where to fill the the pump. It has a 1/4 NPT at the bottom with a l shape drain.
Thanks
mike93lx
Richmond, VA
A picture of the pump would help.
My assumption is that is an oil free, but it's not possible to tell with the pics you provided
C
Cadmandu
Va
I got the manual and it said t the plug below is the dain and the plug above is the fill plug. How do you put 16 ounces of oil in at that height.
Sleeper
With a funnel?
Seriously, why not try draining it and filling it with the recommended oil and see how much it takes. you might be surprised how much it holds in the little space when it’s spread out over the entire area of the sump.
demarpaint
Long Island
With a funnel?
Seriously, why not try draining it and filling it with the recommended oil and see how much it takes. you might be surprised how much it holds in the little space when it’s spread out over the entire area of the dump.
Exactly. Just make sure it is on level ground when you service it. You'll be surprised how much oil they hold.
C
Cadmandu
Va
Ok thanks I read that i should change oil at running temp. So I went to lowes and got 25 feet of 12/2 and a 20 amp 2 pole breaker with a 240 plug and plate.
mike93lx
Richmond, VA
240v? Why?
That doesn't just have a 15a 120v plug on it?.. Don't think for a moment that is actually 4hp
C
Cadmandu
Va
Take a look
C
Cadmandu
Va
The wiring diagram on the motor shows 2 pole only wiring. This unit is at least 25 yrs old and is probably only 2 1/2 working hp nut does require 240 even for that rating. It has a 919. ****** model number so it was built by DeVilbiss. I paid 135.00 for it and it came with 2 25 ft hoses
C
Cadmandu
Va
Cfm pic and motor
Citation
Indy
Edit: Looks like it is a 240V plug, see two posts below this one.
That's a 20A 120V plug. Do not plug that into a 240V outlet. While most 120V compressors are designed to work with a 15A circuit, that model is clearly intended to only work with 20A circuits hence the 20A plug. If your wiring is 20A (rather common) then you can change the wall outlet to a 20A version. Do verify that all the wiring is 20A. When I moved into my current house the visible wiring in the garage was all 12G and the wall breaker was 20A but the place where the wiring tapped into the house wiring was old ungrounded 14g stuff. This is not something you want to run on poorly done 14 gauge wiring.
C
Cadmandu
Va
I think so so too read the label in these pics
claymont
CLAYMONT, DE
I've had this same compressor model since '78. I run on 240v; all I've done to it is change the oil a couple of times; I use a 5w- 50 synthetic because I had a surplus of it and the compressor is in an unheated outdoor space. There's a felt filter pad on the inlet that I clean when I change the oil. Only repair I've had to do is replace the discharge check valve which is located at the end of the discharge line going into the tank. When it fails, the motor will likely trip when trying to start. If you hear a continuous hiss of air at the pressure switch after the compressor has built up pressure and stopped, that's a sign that the check valve has failed. A couple second hiss is normal at cut-out, that's to 'unload' for the next start.
C
Cadmandu
Va
Nice to find a owner of the same model. How can I find out what year it is.
bkdii248
Hi all
Thanks
I have the same compressor hasn't been used in 20 years ago. Looks new when it builds up 20psi head pressure, it shuts off before the uh pressure switch builds up the pressure to automatically kick off. Any suggestions
