Oil Drain Pan for Lift
NotOrganized
I am on the hunt for a decent oil drain pan for my new lift. The Arksen 20 gallon at $150 seems to have more positive reviews on Amazon. I don't necessarily need that much storage, but it would be nice to only need to empty it once a year.
What are you using with your lift? I have a two post.
LX-Markham
Markham, Ont.
I got the Bendpak one for my 4-post, love it.
lakeroadster
Central Colorado
20 gallons is heavy.. 150 lbs
5 gallons = 38 lbs
I made my own using a new 5 gallon gas can, some tubing and a store bought big *** funnel.
The tubing telescopes the funnel up and down.
When full I take it to NAPA, and the guy dumps it and gives it back.
sberry
Brethren, Michigan
I was going to order one and whipped this up at the last minute. I wanted it NOW.
Made it custom fit storage.
N
NotOrganized
I kind of like the idea of being able to fill 5qt jugs I can drop off at the recycling center. I like the larger air emptying ones, just wish it had a hand crank instead. I'll probably just mod one with a shut off on the hose like others did.
Thank you all for the responses.
N
NotOrganized
I went ahead and ordered the Arksen 20 gallon one on Amazon. I hope the quality lives up to the feedback. I plan to pull all of the fitting apart and put new teflon on to make sure they seal. I appreciate all the great comments. Almost swayed me to the Lisle.
mrobins297aaa
south east michigan
I have a 8 /10 gallon, which I added a 12ga ban around it so I could lift it and empty it using my lift. Took all the heavy lifting out of emptying it and most of the mess.....even though I can tip it carefully I still manage to get oil all over........lol but at least I don't have to lift it and try to pour it by hand.
N
NotOrganized
I am considering sealing my floor to keep the inevitable spills from soaking in and making it look bad.
N
NotOrganized
Ya, I am reading on the flooring section to get some inspiration. Floor is one year old. A few tire marks but should clean up fairly well.
Lelandwelds
Central Texas
Now I have truly seen everything. I like the way you think.
Matt M PA
SE PA
I too have the HF oil drain-lift. Works very well....but a caveat if you get one....
The first time I tried to evacuate mine, I made quite a mess! Turns out, I put too much pressure in, and had no way to stop it. I installed a quarter turn valve just ahead of the pressure relief switch on mine to bleed off pressure. This way, I can drop the pressure to stop the flow of oil when evacuating.
I originally bought one of the smaller, plastic versions but found it a bit difficult to empty.
Graham08
Iron Station, NC
I have the smaller Lisle one as well and like it quite a bit. Something to remember is that in a lot of cases, parts stores, recycling centers, etc. will only accept less than 10 gallons at a time. The bigger containers limit your options on where you can dispose of the oil.
pbon
For a DIY use, I’d stick to a 5 gallon. I use the HF one. I drain into my 5Q empty oil jugs and drop off at recycling. I don’t want to roll around or store 20 gallons of used oil or store a bigger oil drain in my space limited barn. For a shop, I’d get a bigger one but I have only 3 cars and 5 gallons is more than enough to do all 3.
59 wagon man
hollywood fla
cheap one from harbor freight with the 20% off coupon was about $50 then i bought a 24" x 24" flat drain pan that fits on top so i can pull the oil pan plug and filter at the same time
N
NotOrganized
I would never try to transport a 20 gallon oil can. I’ll just pump it back into the original 5 liter jugs and drop them off. It’s what I did pre lift. Balance a funnel on the jug and pour from a pan. I am hopeful my new setup requires less cleanup when done. Time will tell.
sberry
Brethren, Michigan
I usually scoop and burn a little oil but got a different stove. I used to have a 275 but since modern oil change schedules came along can get by on 55 especially if I burned it off during the winter.
We use so much less than 20 years ago, went to small package for most of it.
Oregon rock crusher
West of Salem
Here is another option. Drum bottom drain pan incorporated in to a chopped up HF cart. Stores over the cart with no added footprint. With it spun out to the side I don't get many drips on the cart which is usually under the vehicle anyway. Flows down a standard pipe to a five gallon jug or one of the 5 quart jugs the oil came in. Really handy for pulling the pan on automatic ******'s. Sometimes for simple oil changes on small cars I just use the Blue pan and pick the bowl off to dump. Ed.
SouthLake
Jersey Shore
I use the little 5 gal one from HF as well in my home shop. its compact, easy to store. and when its full i just run it to recycling center. you can buy a cap for the main fill hole at HD, just standard pipe thread to seal it for transport. i cut down the extension pipe a little so it fits under mid rise lift comfortably.
the 20 gal gives you a lot of capacity if you have a bunch of engines, but takes up a lot of space and its a extra step to recycle the oil in it vs just bringing over your 5 gal can and dumping it.
sberry
Brethren, Michigan
If I had to take somewhere in that sense would rig it up into 5 gallon custom or translucent jugs with a hose from the drain pan. One shot handling. To tell the truth can about count on fingers the number of changes in the year.
firebirdparts
Kingsport, TN
I use that one too!
I don't dare let it get full, as you observed, it's hard to empty. Busted the funnel about 10 years ago, but the rest of it is still going.
sberry
Brethren, Michigan
If I had a lot,, or more than I do that home brew above is exactly what I would do with the addition of a screen to set stuff to drain. I like the valve at bottom, fill any container.
