Oil Drain Pan - Recommendation
PoorUB
Fargo, ND
Leave it sitting on the drain pan until the next use?
Fine if you use it often, but oil changes in my home shop are far between so my waste oil jug gets sealed up and slid under the bench. I'm not leaving that oil soaked fiber laying there for the next oil change, six months from now.
jollygreengiant
Ontario, Canada
This is what I use now for vehicle oil changes. You can either put the oil pan on top of the base to roll it around, or what I mainly do is use the drain pan separately so that I can put my tools and such on the base. really nice to have all that stuff in one spot that I can easily move around. I'm not a big fan of the spout design though.
whateg01
doo dah, kansas, usa
Since we're talking about automotive stuff, we really need to stop calling the drain pan an oil pan because the oil pan is the thing that's stuck on the bottom of the motor and the drain pan is the thing that we drain the oil from the oil pan into when we're changing the oil
SteadyC
CA
Like an engine/vehicle vs motor/electric?
Roert42
NE Penn
If it's for used oil that's going back to the parts store or the local household hazardous waste, why does it need to be clean?
Less likely to have dirty oil drip all over the place. Plus it attracts dirt and ****.
Also I use it for other fluids, better to not mix coolant and oil, ect.
SteadyC
CA
Lisle 38800​
Lisle 17972​
5 gallon plastic gas can for transport/recycling.
ATC
VA
My drain pan is vertical, on the wall. That thing would drip oil all over my toolbox.
Well, no, it wouldn't work in your situation.
I leave my drain pan sitting on top of a 30-gal oil drum full of stay-dry/kitty litter, so that storage solution would work for me, and many more who store their drain pans flat on the ground.
mrvm
PA
Agreed....since I have multiple vehicles to maintain my oil drain pans are stored flat in a 3'x4' plastic deck box outside along with a few 5 qt bottles of used oil waiting for the next auto parts trip to recycle. The oil drain pans are wiped around the rim and bottom with a rag but definitely not the insides. If the mice and stink bugs want to take an oil bath oh well...
Chipm
Georgia
Best advancement in decades
It is absolutely amazing how well this works. 15 yrs ago when I was a tech at a Lexus dealer the SnapOn man came in w/ one of these. He walked through the shop looking for an oil drain about to happen. Asked the guy to wait a minute and yelled for all the other techs to watch. Almost every tech bought or ordered one. Next week I had mine and spent the following week trying to make a splash. Couldn't do it.
Ordered a set - thanks.
slowtwitch73
Hellgate
Saw a guy on YT last night using an old beat skillet (non stick Goodwill variety) and I slapped my forehead. Brilliant.. nice long handle, tallish sides, cheap....
PhantomEB
Medicine Hat, AB, Canuckistan
I use one of the black round pans with a spout,
luckily my Cummins has one of those filler tube adapters that I can use to shutoff the flow.
All oil goes into a 5 Gallon pail unless a camping trip is coming up which then I fill up a couple 5L bottles to take camping for firestarters!
mikegt4
sw ohio
That kind of looks like a urinal that has been run over by a train.
Fixr
SW VA
Ahhh **** green is for coolant ?!
It is in my garage, even though I currently have Toyotas that just use pink/red coolant. I have nearly 40 years experience of coolant being green, so it's pretty easy to remember.
whateg01
Probably a great idea, but I'm not willing to schlep 15 gallons at about 7lbs a gallon. That's over 100 lbs. Or if it's 15 quarts, that's still over 25 pounds.
The description says 58 quarts. My math says that is almost 15 gallons. But it has handles and wheels.
Fixr
SW VA
My limit is a partially full 5 gallon container with a spout so I can neatly pour it into the 275 gallon tank at the transfer station. Typical petroleum oils are around 7 pounds per gallon, So 35lbs per 5 gallon can, and around 100lbs for 15 gallons. I'm no longer up for lifting 100 lbs above waist height in order to pour it neatly into that 275 gallon tank.
PWC Repair
Arkansas
I just picked up one of these. I like it but discovered the rate of flow out of the "pan" on top is slower than my mustang will dump 10 qts.
I'ma need to get in there with a drill and open that up a bit.
Did you have the vent popped open? If not, the oil can't get into the pan quick enough.
Fialaja
finn
The UP, God's country
For years I used an open top oval shaped aluminum pan with handles on each end that my dad brought home from the steel company ores processing lab he worked at in the fifties and sixties. It was pretty beat up when he got it, and hasn’t become any prettier with time, but it will never rust.
About forty or so years ago I upgraded to a black plastic closed top container like others have shown, with a spout. Big improvement.
Last year I upgraded to a red plastic receiver by Lincoln for use under the lift.
Truth be told, it’s easier and quicker to take the daily drivers to the dealer for routine oil changes now. Both the Ram / Jeep and Ford dealer have been doing oil changes for $ 42-46 for a few years now. I’m not saving much at those prices and don’t have to deal with disposal or clean up.
Still do my own changes on project cars, though.
Numerator2142
Yeah it was popped, but I need check that hole goes all the way through too. I think it was just the flow rate out of a ~3/4" diameter hole was higher than the flow rate out of the 2 1/2" diameter holes from the drain pan to the tank. It'll take longer to clean the oil off the drill bit than to actually fix it.
hobie18
Same here. Did a few changes. Including an hour ago. Only time the vent cap actually worked. 😟. The plop plop is not the time to open the car oil cap, or pull the dipstick. Oops quick open the drain pan.
smackey05
Massachusetts
I have the open top version of the same thing. I kinda wish I had the closed version, as it would be nice to have a spot to set the oil filter to drain.
This is like the one I use. When finished, I empty it into the previous oil container for recycling and shove a rag into the spout to stop the dripping.
tworley
Colorado
Flotool 42004. Once I'm done draining, I clean the the drain valley real well and cap it until I'm ready to take it to recycling.
I did recent crack the drain spout cap for it though, anyone know where to get a replacement?Screenshot 2025-01-06 at 08-50-55 Hopkins FloTool Drain Pan 42004MI O'Reilly Auto Parts.png
4xdog
Santa Fe, NM
Costco has this made-in-USA 13-quart FloTool Extender Drain oil change kit online these days for $35. Item number 1963155.
4000385820-847__1
Codyboy
S.E. TEXAS
I have yet to perfect it but I use a cardboard box with a garbage liner in it.
With the right size bag liner it works pretty well.
The box corner makes for a good spout for pouring back into an empty 5qt jug.
Place the filter in the bag after draining it. Throw the bag in the trash.
pbon
That would be about 18 lbs of oil in the cardboard box for one of my cars. I have used that technique when a drain pan was not available but it is not one that I like. The Costco pan liked above looks good to me.
fourjeepin
Atlanta, GA
I bought this 6 years ago when there was another similar thread. Ive been real happy with it.
cad70
NE
For the truck and tractor I use any common five gallon bucket I have laying around. I throw a lid on it and take it to the dump and pour it into the oil recycle tank. Anything else I join those before me in recommending this which then gets poured into a five gallon bucket mentioned above…
That one will splash oil everywhere, and the cap does not seal worth a darn. It will weep oil forever.
no704
Had roommates for many years. I ended up with 4 35gal malt barrels over flowing. Plastic. Seemed like a great idea at the time. Took me a whole day with 4 5 gallon buckets to take to the a Orileys. Manager said I was only allowed 10gallons per day, but just bring it. I love my ORilies. Never again will I have more than 5 gallons.
Uncle murph
Harford county
Typically use the Dollar Tree cheap pans that I throw away after every use - considering buying a real one that I can re-use.
Does anyone have a recommendation on a oil drain pan that has a top that open/closes? I don't really want one that is just a pan that will always be dirty and left laying around, a kid can get into. Thanks!
I cut a hole in the side of a two gallon jug which originally contained Ford New Holland 15w40 around 1996 and have been using it since.No doubt hundreds of gallons through it since then.
