I have a round pan like yours but the cap at the spout drips so I can't use it for transport. These are all cheaply made, best system I've ever used is a Lisle 4.5 gal. pan that is only for collection, no transporting. Thick plastic that doesn't flex, and a great spout that fits nicely inside the mouth of the 5 qt jug the new oil came in - no need for a funnel. I then use the old jug for recycling transport - easy to handle and has great cap and seal that won't leak even if it falls over. That's my recommendation.
Same one. LOVE it.I have a round pan like yours but the cap at the spout drips so I can't use it for transport. These are all cheaply made, best system I've ever used is a Lisle 4.5 gal. pan that is only for collection, no transporting. Thick plastic that doesn't flex, and a great spout that fits nicely inside the mouth of the 5 qt jug the new oil came in - no need for a funnel. I then use the old jug for recycling transport - easy to handle and has great cap and seal that won't leak even if it falls over. That's my recommendation.
Replace the cap with one off a anti freeze or washer fluid bottle and it wont leak anymore.
Hopkins makes a Heavy Duty model but it's not low profile like the OP needs. I typically just use the old oil containers for transport. If you want something fancy you could always get something like this...https://www.amazon.com/Hopkins-FloTool-11849-Dispos-Oil-Recycle/dp/B0014FKI1Q/ref=pd_sbs_263_11?_encoding=UTF8&pd_rd_i=B0014FKI1Q&pd_rd_r=R412PY2J2E788SQ6FDYQ&pd_rd_w=h8tOZ&pd_rd_wg=UUIVm&psc=1&refRID=R412PY2J2E788SQ6FDYQ
I've had this one for over a year it worked okay but it just started leaking from a seam in the plastic. I liked it since i could take it up town and recycle oil from multiple vehicles. It needs to be low profile.
I hate those integrated drain pan/container combos. The pan is too shallow so the draining oil splashes all over the ground and bottom of the car. Use a separate drain pan and container. I have this pan:
and a 4 gallon plastic container to take to the dump.
This is the one I use and recommended, easy to drain and transfer w/o splatter+1I use a metal pan which I empty into a 5-gallon bucket and take to the recycling center when it's 3/4 full.
https://www.amazon.com/dp/B000BOB7RU/?tag=atomicindus08-20
holds 20 gallons
I put all my drain pans in it
13 bucks
https://www.homedepot.com/p/Large-Mixing-Tub-26101/300488529?keyword=cement+trough
No leaks with this container - been in use for several years now.
http://geoplastics.com/oil-recycling-containers-15-qt
Ryan
Got a link for that one? Thanks!
It is probably polyethelene and greasy to boot. Virtually no glue works on that stuff. It probably could be plastic welded if it wasn't all greased up, but definitely not worth the trouble. Another vote for separate pan and jug.I would just repair it with super glue.
Mine was the cap that cracked. I super glued it about 3 years ago, no more leaking.
I only use it to drain oil and pour the oil into a milk jar for recycling. Don't want to risk a mess in the trunk.
I've noticed that almost all the oil pans in stores are "Made in USA". The quality is definitely not better than stuff from Walmart.
holds 20 gallons
13 bucks
I use the little brother of that one.
Why Risk It? If that glue seal fails, especially with the flexing plastic as the oil sloshes around - Oh Boy!!! Imagine opening your trunk at the recycling center and finding several gallons of dirty oil everywhere.
Looks interesting, but the site doesn't have the dimensions of the thing anywhere, which is baffling, they don't have anything about where you can buy it, and Google shows no hits for it but the manufacturer's site. Apparently they don't want to sell them.
Any idea where to get one?
Why are you buying quart bottles of oil? The 5 quart jugs are a lot cheaper per quart.
