Oil Drain Plug Bolts
guitarbutt
Mechanics and folks who change their own oil, what size wrenches and sockets do you use to remove the drain plug? I'm wanting to put a set of commonly used ones together. My family vehicles use 15mm, 17mm, and 5/8
ChevyEFI
Phoenix, AZ
VIM has a deal on 6 common size wrenches for plugs, last I checked.
We have 13, 15, 17 on driveway vehicles.
cmandp
New Jersey
Seems you know what you need for you're family's vehicles. I've just added on tools as needed.
Chevy S10
15mm wrench for drain plug
Band style oil filter wrench (if it's very stuck)
Saturn L300
T45 socket
3/8" ratchet for oil canister cap
Hyundai Elantra
17mm wrench
Universal oil filter wrench with 3/8" sq. drive
I also bought a 32mm (?) socket for the GM Ecotec canister filter caps as I did my wife's grandmothers oil once.
bwringer
Indianapolis
14mm on Toy Yoda oil drain plugs. 3/8" drive square on cartridge filter housings.
10mm hex on many Toyota transmission drain plugs.
My motorcycles use 17mm and 21mm.
Ralf11
ko-ken nut grip sockets can be helpful here
Snappy makes a nice 17mm Allen for trans. drain plugs
blarf
Engine oil drain plugs aren't where things get weird. A long handle flex 3/8" ratchet + socket will do you most of the time. Volvo liked their 25mm (and 22mm) drain plugs so about the only SAE socket I have is the 1".
Oil filters come in all sorts of crazy shapes and sizes though. I use a thirty-something millimeter socket on the BMW's cartridge oil filters. Some sort of non-conducting strap wrench on the Volvos (putting the oil filter right behind the alternator is something you only forget once).
Transmissions and diffs use some oddball stuff. I keep a stubby 17mm hex bit for the diff and a 14mm one for the transmission fill/drain. The one piece NAPA/Carlyle ones are nice enough.
G
guitarbutt
What is VIM?
And thanks to all who answered, I didn't have a lot of luck searching for the answer. Very helpful
Iowafox
Iowa
I say 13mm, 15mm, 17mm and 3/4 or 19mm.
My wifes 2019 Ford Escape sel has a 13mm drain plug.
My 2007 Honda Odyssey ex-l has a 17mm,
2000 Silverado has a 19mm
and my 1977 Oldsmobile Cutlass has a 3/4 (19mm) plug.
I almost say just go to NAPA or your preferred autoparts store and buy a 3/8 drive set of metric shallow sockets and keep them for your oil change kit.
that way you always have the size you need and spare sockets to boot.
2ndGearRubber
Pittsburgh
Frankly it makes more sense to just get a set of 3/8 sockets, than piece together a set to cover all drain plugs.
10/13/14/15/16/17/19, and 6/8mm hex bits. Torx for some euro stuff, t30-t45. Flat-head screwdriver for newer VAG stuff, or buy the proper tool for $25. If you wanna be real picky, 8 point sockets for pre-60s stuff.
Just buy a set of torx/metric hex. shallow 6 point in 3/8. Add in a wrench set.
Mick56
Janesville Wisconsin
After I change oil on a vehicle I bought, I write the size needed on the radiator support with a magic marker. Only need 1 wrench or socket the next I crawl under there.
G
guitarbutt
Thanks for the extra replies, it looks like 13-21 should cover pretty much everything. My 87 Ford has a 7/8 though, I thought it was smaller but I double checked today. It's cold so I didn't check to see if a metric was a fit as well
G
guitarbutt
I have a lot of spare mismatched sockets I was wanting to make good use of, but I'm not a mechanic yet so I was wanting to get prepared
Dumber than lumber
Look into getting Fumoto valves for your cars. Sure makes things easy.
I mean, you don't even need a wrench once the valve is installed. Of course, you still need to change the filter, and drain the oil.
ecotec
I have the ValvoMax oil drain valve on my car. I have only changed it once since I got it. It is much less messy, doing an oil change. It drains down a tube right into your container. You still have time to make a mess while changing your oil filter, though.
I have an Assenmacher funnel that threads into my oil fill cap’s threads. I do not spill a drop while refilling my car with oil.
dwasifar
14mm on my Subaru, 17mm on my wife's Subaru.
I'm swapping mine for a 17mm drain plug next time, to keep things consistent.
setfocus
rust belt
13, 14, 15, 17mm are the most common. 13 and 15 for most domestics, 14 for toyota's and other asian cars, 17 for honda's.
I use a craftsman dog bone wrench that's 12-15mm one end, 16-19mm on the other, for most drain plugs. Some mazda's use allen, some vw's use torx, small gm ecotec's use 10mm, older domestics can have larger plugs and replacement plugs can be different sizes
G
guitarbutt
I believe I am going to get the dog bone wrench. It seems perfect for this job
zeke67
Houston
This is what the dog bone wrench is for, right? Add the Snap-On three fingered self tightening oil filter went for anything you can get a 3/8 ratchet on.
