Oil for ratchet mechanism?
marlinspike
Virginia
I have an older ratchet that has started to get gritty, so I took it apart to clean and lubricate. I figured the 75w-80 LT2 gear oil BMW makes for their manual transmissions would be sufficient, but the mechanism got a bit louder. Now, is that a good loud meaning I'm getting nice positive engagement of the teeth, or is it a bad loud meaning I need a thicker lube?
refried
San Juan Islands, WA.
your supposed to use a light oil (3 in 1 is good), but I use a good waterproof grease because mine see lots of use around and in salt water.
Fedwrench
Valley of the sun
Many choices available for ratchet lube. Some people here are as passionate about their ratchet lube as their favorite car brand or hair color on women.
However, I prefer a slightly thicker lube like engine assembly lube for ratchets with less than 45 teeth and a thinner oil such as air tool oil, 3 in one, or Brake Free CLP for finer toothed ratchets but, that's just me. Use what you have on hand and what you can live with leaking out.:beer:
