Loose Ctrl
Lennox oil furnace in a 1500sqft house.
My mother's oil furnace went two years without service. She had it serviced before Xmas. The tech said that the furnace was overloaded with soot and carbon which clogged the nozzle and blocked the photocell that looked for the flame. The furnace would come on but the process to start and run the pump and igniter would fail. After a predetermined time, the fan would kick on. The tech made some adjustments and got the furnace to run. A month later the same thing happened. The week before, I noticed the furnace was pumping out black smoke like an over fueling diesel truck.
Oil furnaces are no longer a common heat source in my area. We only have one company that services them. They are known for underhanded practices. Is it possible that the tech could have adjusted something just enough to get the furnace going and cause the same issue again? They were pushing hard to up sell a new HVAC system complete with all new duct work which would require all new electrical work and some plumbing as well.
Well, from 1994-2009 I was on the NFPA 31 "Oil Installation" Code Committee, and for 25 yrs represented multiple manufacturers of oil heating equipment in the six New England States and trained a lot of oil techs and grew up with oil heat. I don't miss it. Its time has passed.
