Fuel Comparison Calculator for Home Heating
Cost per Million BTU Calculations.
Fuel Type Fuel Unit Cost per Unit BTU per Unit Efficieny Cost per million BTU
Coal(bulk) Short Ton(2000 Lbs.) $ % $08.33
Coal(40lb. Bag) 40 lb. bag $ % $15.62
Coal(50lb. Bag) 50 lb. bag $ % $14.58
Wood Full Cord $ % $16.23
Wood Pellets Short Ton(2000 Lbs.) $ % $21.65
Corn Short Ton(2000 Lbs.) $ % $21.65
Fuel Oil No.2 Gallon $ 138,690 % $30.90
Electric kiloWatt-hour (kWh) $ 3,412 % $35.17
Natural Gas(Therm) Therm $ 100,000 % $14.75
Natural Gas(Mcf) Mcf (1000 cubic foot) $ 1,031,000 % $14.74
Propane Gallon $ 91,333 % $27.37
Kerosene Gallon $ 135,000 % $27.78
Reverse Calculation
This section will give you a real world estimate based on the Cost/BTU/Efficiency values in the calculator above, values used above will effect estimates in this section. If for example you use $500 worth of fuel oil in one month you can select Fuel Oil from the drop down list and type $400 in to the text box. Hit the recalcualte button and you'll get estimates for what it would cost if you were using another fuel.
Coal(bulk) Coal(40lb. Bag) Coal(50lb. Bag) Wood Wood Pellets Corn Fuel Oil No.2 Electric Natural Gas(Therm) Natural Gas(Mcf) Propane Kerosene $
Coal(bulk) $1,000.00 Coal(40lb. Bag) $1,875.00
Coal(50lb. Bag) $1,750.00 Wood $1,948.05
Wood Pellets $2,597.40 Corn $2,597.40
Fuel Oil No.2 $3,708.17 Electric $4,220.40
Natural Gas(Therm) $1,770.00 Natural Gas(Mcf) $1,769.16
Propane $3,284.68 Kerosene $3,333.33
