Oil or Oilless Compressor after 22 yrs
pauls340
North of Motown
So after 22 years my Sears Oil free torpedo compressor needs to be replaced. i'm looking at the Harbor Frt 2.5 HP 21 gallon cast iron vertical OIL compressor. Am i going to notice any difference in the Oil versus Oilless? thx
DemoFly
Port Orchard, WA
You're going to have to break in the motor properly...and of course change the oil every once in a while.
It will also likely pull more amps on cold start than a comparable oil free.
Instead of a harbor freight, take a look at Husky's offerings. I was shopping the two brands around Christmas time and went with the Husky...just felt like a better product.
Dhagan887
After 22 years of listening to an oil less compressor, you may not, but the neighbors definitely will.
DemoFly
Port Orchard, WA
Stupid question, how do you break in a motor properly?
Probably different for every compressor. But for mine you have to open the drain valve and let the motor continuously run for 10 minutes to set the rings.
I then opted to change the oil, WHICH I HIGHLY RECOMMEND, and tons of shavings came out. Tons.
NuthinFancy
SE Wisconsin
Ok, I'm new to air compressors; is there significant difference in sound levels between oil and oil-free compressors for a given size?
I see a number of compressors listed as "quiet" and "ultra-quiet", but the decibel ratings don't always agree.
TIA
MrGiggles
I have had that compressor for a year now, and have no complaints about it. It spent many hot days last summer running a DA sander almost continuously. As someone already mentioned, if you get it, open the drain and just let the pump run for a few minutes, then change the oil. It is loud, but not unbearable as long as you aren't standing next to it.
TIA
Drive type has more to do with noise level than oil or oil-less. Compressors that are direct driven with the pump bolted to the motor are very loud compared to belt drive units, whether they are oil lubricated or not.
CNGsaves
KS and OK
OP . . . there are few exceptions where Oil-Less compressor would be good:
. . . . . . California Air, Husky quiet that is in HD Clearance thread, Rol-Air, etc.
These are small mobile compressors that you can run nailers, pump tires, etc.
For anything bigger, get yourself BELT-Driven and oil-splash compressor if you step to medium size compressor.
I suggest having . . . TWO Compressors . . . small mobile one, and larger stationary one depending on your needs.
TangoFoxTrot
TIA
Yes, it's very significant.
I don't know enough enough about the engineering to know all the reasons why, but it is night and day in my experience.
I have both, and the oil-less is like gravel in an empty paint can being violently shaken. Very loud rattling noise.
An oil filled compressor is more like a dull sound, like a car running in idle.
The difference in sound alone is enough reason to go with an oil-filled in my opinion.
