Oil resistant spray bottle
dnschmidt
Phoenix, AZ
For anything oil based I use a Shur-Shot. These are great for wax and grease removal in autobody but these rust if you put waterbased materials in them.
darkzero
SoCal
While I absolutely hate the normal yellow & blue ZEP spray bottles because every single one I have had failed even just spraying water, the ZEP black (and clear) Chemical Resistant spray bottles have worked well for me spraying water soluable oil based coolant.
Not sure what your application is but if what you want to spray id heavier on the oil side I wouldn't look for a pump action spray bottle.
Roert42
NE Penn
I’ve used the clear ZEP bottles for WD-40, transmission fluid, and PB Blaster.
I’ll also will reuse old windex bottles.
JABgj
So. California
There is a white and blue spray bottle with WD40 printed on it on Amazon. Material stated is PTFE which might hold up to
solvent and oil better than milk bottle plastic.
