snyder
I need to add a quart or two of oil to my new (used) rotary mid rise scissor lift. Not sure what type or where to get it. There is a tractor supply nearby.
Thanks.
Thanks.
Please do not use ATF all in any hydraulic system unless the manufacture of the equipment recommends it.
ATF has a whole heap of additives that can attack the seals causing premature failure.
I don`t know how many soft gooy seals I pulled at of hydraulic systems that have had ATF in them.
The stuff thats in there is clear not red. I did find a rotary manual on line. It calls for a 32 hydraulic fliud with a full alphabet of letters in front. I had a local hose company make a 26 foot long hose so i
could mount the pump unit on the wall. It worked out really good, but i lost some oil. I will check tractor supply next time im there. Thanks all.
