Okay guys, I need ideas.
Skooterj
Indiana
My garage is going to be dried in soon, but the budget is going to stop me from getting the driveway approach poured this year. The current gravel base is about 4 inches below the garage floor slab. I know my pickup can make the jump, and I can put my motorcycle on my trailer and use its ramp to get the bike in the garage, but my 76 MGB just doesn't have the ground clearance. Any ideas for temporary ramps just to get the car in and out without scrapping the bottom? The approach has a drop at both sides, but is long enough I can fit the MG in the middle, so a set of down ramps that I can reposition to be up ramps would be perfect.
larry_g
oregon
I'd just build it up with a load of gravel and call it good. You're going to have to grade things before you pour so just pull the gravel out when you get ready to pour.
lg
no neat sig line
BMWBOB
Washington State
I'd probably get a pickup load of gravel to ramp to the slab. you'll need to do some dress-up with at least a blade by spring prior to pouring anyway
ynned
N.E. Ohio
Just lay down a few 2x6 or 8 to make tiny 1 1/2 inch steps. Even an English car should be able to climb that.
charbar
Midwest
Gravel will more than likely push/blow out any time you pull something in and out. Some rock would probably be a better idea in my opinion.
NUTTSGT
Northern Central Ohio
Gravel, rock, stone all the same thing around here. Potato/potatoe
Granted, you don't want all 57s or #8s. Going to need some 411s or 304s with dust in it to compact it in.
*All numbers above are in reference to what the local quarry uses for sizing of limestone.
eegger
WI
A little gravel ramp would be best.
any left over pallets and 2x6's or bigger to make a movable ramp or two ?
kbs2244
"Just lay down a few 2x6 or 8 to make tiny 1 1/2 inch steps. Even an English car should be able to climb that."
a door wide 2x8 with a 2x6 on top will give you a stable 3 inch ramp
andyvh1959
Green Bay WI
I'm in the more gravel line. If you want something easy and near permanent, use gravel with "fines" in it and rent a walk behind compactor. Compact it about 2" below the slab height, then get limestone screenings (all fines) put that down and compact it after spraying it with water. By the time you're done it'll look almost like cement.
Joe Reed
Cordova TN
Just get a couple of treated 2x6 boards and make two ramps to fit the track of the MG. Put some blocking under the ramps as needed. Pin the ramps in place with a couple of short pieces of rebar driven into the ground.
At my last house the garage was deep enough to tandem park my MGB and the Miata I had at the time - but there was a 4" step up on the slab at the rear part of the garage....it was really just supposed to be a storage area. I used ramps like that to solve the problem and they worked just fine. The MG just isn't that heavy....
imagineer
I might be late to the party, but I too have a pole barn with a (badly) poured concrete floor and the rise to it from the side lawn is more than my '72 MG Midget can clear without scraping.
My solution is two pieces of 3/4" plywood, about 12" x 30" (recovered from an upcycled shelf unit). I have the concrete marked where to position the boards. Given that the 50-year-old Brit weighs only 1600lbs or so, the plywood is plenty strong enough for the task.
My only gripe is having to unfold myself out of the car each time I arrive back home to go into the barn, unlock and slide open the door and set the boards. . . then fold myself back into the Midget to pull it in.
andyvh1959
Green Bay WI
Its called a "Midget" for a reason? Strange the Brits didn't have some other totally goofy knickname for it. Like the bugeye Sprite.
gahrajmahal
Cincinnati, Ohio
ours has this stupid spoiler on it that the previous owner put on it. I’m scraping it on lots of stuff. I can’t wait until I get other projects finished and I can put the original splash pan on it.
I think I’d choose the wooden ramp version. Or gravel, I mean gravel.
thebmrust
TL/DR the above posts but I don’t know if anyone mentioned a simple idea… just drop down more gravel. Sorry if it was said before. Good luck.
Edit: take pics and keep us updated.
/sarc
Swervyjoe
SC
Gravel would be better, but a temporary fix that probably wont be as temporary as you're planning.
Ramps will work and be enough of a pain that you'll likely expedite pouring a driveway.
Skooterj
Indiana
I built a couple ramps from some scrap 2x8's I had. They worked fine. Hoping to pour the approach next spring. Car and bike are out of storage and back home. Now to pull the intake and replace the gasket. Then replace the floor pans.
Slednut
Washington state
I'd move the gravel rakes or your car.
