Okay Guys, What the Heck is this?
Realmongo
Western Massachusetts
Someone gave this to my nephew who passed it to me. It is stamped Manzel-Buffalo 7195
you sure it's not a saw set?
okay... well... after looking, it appears Mr. Manzel manufactured a "leaf spring lubricator" and he was located IN Buffalo New York.
but your device is NOT the "leaf spring lubricator" of Buffalo fame.
Manzel / Charles W. Manzel Co., Buffalo, NY / leaf spring lubricator / patent 1201324 Oct 17 1916 & 820979 May 22 1906 Charles W. Manzel / https://flic.kr/p/GQvgVj / (* existing specimens are stamped with date of Oct 18 1916 *) /
so... it's possible that it's actually a saw set, but I will have to defer to @Old Man Roger on that one. ;)
R
Realmongo
Came from a long closed Ford dealer.
larry_g
oregon
Beerhippie
Far NE Oregon
That reminds me--when was the last time I greased my leaf springs?
shanny19
PNW
IDK, but I’ve got four vintage grease bars, aka rattlesnakes, aka shackle bars that haven’t been used for their intended purpose in probably 70 years. Want to borrow one?
Beerhippie
Far NE Oregon
I guess I'd have to buy something with leaf springs first. I don't think I've owned any in a few decades. I also don't recall ever greasing any that I did own--or being aware that it was a thing.
gungatim
west mich
It was a thing before they put wear pads between the leaf ends. And leaf springs are still pretty common.
If you've ever had a pickup truck, travel trailer, boat trailer, utility trailer, etc. aside from the occasional torsion axle, they pretty much all use leaf springs.
dchawk81
I was gonna say...talking as if leaf springs are rare is strange. Greasing them is no longer a thing, sure, but they're everywhere.
I have 4 vehicles with leaf springs. One trailer, one pickup, and both semis have leafs in the front. Even brand new ones do.
Ricky Joe
Roanoke, Va.
Leaf springs used to be greased. I’ve worked on lots of old cars and trucks that suffered from wear due to not being greased, leading to loose shackles, broken springs, and worn helper suspension. Eventually, not sure when, leaf springs were alternated with thin Teflon or other material similar to keep the metal from wearing as the springs flexed. There were several styles of greasers, even some designed for the old enclosed springs. Don’t you just miss the sound of unmaintained springs squeaking on a dirt road?
Beerhippie
Far NE Oregon
Everything I've driven in the last few decades has had torsion bars, coil-overs or MacPhearson struts. I've owned a lot of leaf springs over the years, but a long time ago for me.
The only leaf spring I currently own looks like this:
and doesn't require greasing.
Modern Garage
Southern Minnesota
When I was in school (back in the dark ages) we learned to overhaul automatics with external adjustments. Shortly after I began to make my living repairing cars I realized that if the band(s) on any trans made since 1959 needed adjustment it was because it was worn out and needed an overhaul.
The manufacturers realized it too because external adjustments disappeared.
Joe
Old Man Roger
Palm Coast Florida
Joe
Right, but wouldn’t you need to adjust the new bands?
Modern Garage
Southern Minnesota
Yes, as part of the O/H. I was just pointing out why most have never heard of "adjusting the bands" since it was never really a maintenance item since the Model T days.
Reminds me of an old cartoon of a guy up to his elbows in grease repairing the T while his wife says " What do you mean we need a band, we're just going on a picnic, we can sing songs."
Guess you hadda be there...it was funnier in 1926.
Joe
disston
Silver Spring, Md
I remember a story my brother once told me, He's not the mechanic guy in our family, I am. He said he took his truck into a transmission shop and told them he wanted the bands adjusted. They looked at it on the lift and told him it needed a rebuild. Well, that is the correct advice when somebody says they need a band adjustment, there are no band adjustments externally on anything you are likely to see today. I told my brother, Do Not tell a transmission shop to adjust the bands. Only service on a modern transmission is changing the oil and maybe putting on a new filter. I now have a 2018 car. The filter is only changeable by taking the transmission off the engine.
I was learning boat mechanics a few years ago. Rebuilt a 1967 Paragon HJ7C transmission using a manual for an older HF7 transmission. Only difference in those two transmissions is the placement of the external band adjustment. I learned this after or during my disassembly of the port transmission so I was then able to adjust the starboard trannie and drive my boat on one engine.
Had trouble managing my time and efforts, ended up having to sell my boat, yeah I know, great day.
disston
Silver Spring, Md
I did rebuild a 1988 Ford AOD trannie once. Took two years and two parts trannies to practice on but it worked great. That trannie went thru several changes in later years. Mostly adding electronics, but mechanicals stayed much the same. I almost became a transmission guy.
I'm too old to get a real job now. I was too lazy when I was younger.
Any real transmission guys here?
