Old air compressor motor replacement or???
Shoreline_
Springfield, MA
Awesome that's great. It's a good pump these never really went higher than 7.5hp. Even tho you could order it as as a ten a ten would be a screamer. If you went 10 or 15hp with would be the next size up t30 which I think is a 15t. Pretty sure the t30 went up to 25 or 30hp pumps before getting into real industrial recips like the IR ESH, LLE, XLE.
Dagny
Northern Wi.
Stuff back the was made to last a couple life times. ker plunk ker plunk. I call the new stuff screamers.
T
Tipton
Got the flywheel machined. Enlarged the hole to match my new pump shaft and cut the keyway. Sprayed it with some truck bedliner and mounted it. It turns nice and true now.
T
Tipton
This project is finished. New electric motor, wiring, paint, flywheel repair and added an indicator light. Just need to do a little plumbing. Oh, and I also moved it inside my shop. No more birds pooping on it, neighborhood cats sleeping on it, and dogs lifting their legs on it.
