Old battery charger
Hot shot
Virginia
Have an older charger that needs new cables
Is it possible to get a set of jumper cables (same wire gauge as charger) and put them on
Haven’t took cover off yet to see what’s what
Bogie1632
Southeastern Wisconsin
Yes, you could do that but I wouldn't recommend it. Most jumper cables are pair sheaths so if that's what you have you have to peel or cut them apart. In my experience going either way they will start cracking sooner or later.
A better option would be hitting up a welding supplier or a good auto parts store for some clean, new, same guage cables. I'd also open the back up first to see how those original cables are connected. Might be lugs on the cable ends, might be clamped. Best to see first so if you need extra parts you can get it all at once.
V/R
Bogie
Bottlecapdigger
Ontario
^^^^^. That's what I would do, I rubber type insulation on welding cables are way more durable than the average boosters. Plus than you can make them as long as you want. They always seem to short anyway. BCD.
BillK
Beautiful Southern Maryland
Thats funny . . . . I have the same exact charger at the shop and I am getting ready to do the same exact thing to mine except mine needs a new power cord too. I dont use it much any more, mainly to charge the battery on my small fork lift.
H
Hot shot
Virginia
Mine needs a new power cord too
I found a set of cables online
Because I have part numbers for everything
They have lost their mind for the cables price wise
Each end of the cable has lugs
It calls for4awg stranded
Is there a special crimper 1be532a6d8b66655e5ab169466fcf4a1.jpg1d5f96c3c107feb1b4b03c3598fe8d30.jpgfor that size wire
If it is I would have to buy one
I guess the best route is to buy the clamps and some welder wire or Just get the wire from Lowes
BillK
I have had mine since at least 1987 and it was old when I got it. They have lost their minds on those cable prices. I am just going to get a decent set of jumper cables and a good extension cord from Home Depot to make the power cord out of. You can get the end lugs almost anywhere.
H
Hot shot
Virginia
That’s going to be the cheapest way
It will probably be fine because it doesn’t get used very often
MFolks
Springfield Mo.
Some of the battery chargers have rivets,so maybe a #30 drill bit to enable to gain entry,with sheet metal screws holding it closed.
BajaScout
San Diego, CA
https://www.centurytool.net/610258_DC_Cable_Set_p/aso610258.htm
https://www.centurytool.net/6009_Associated_Battery_Charger_Parts_List_s/321.htm
H
Hot shot
Virginia
I’m gonna price both. If it’s not a whole lot of difference I’ll probably go with the welding wire only because of a Ut video I watched where the guy said 4 gauge welder wire had more strands in it
sberry
Brethren, Michigan
If you want to fuss over it then buy new, if you want to use it then fix it with what you can find. I put some off an old jump pack on mine, needed to use it when I fix it and get rid of old stuff at the same time. Added some to the cord when I replaced it, lots of places it saves getting another cord.
H
Hot shot
Virginia
Charger is back in action
2 8’ welder wire
2 deka clamps
1 9’ power cord from Home Depot
$45 for everything
Only problem now is I don’t have a battery that needs charging. Lol
I guess that’s a good thing
Thanks for all the advice
